99 mustang gt help - Mustang Evolution
Old 04-07-2013, 09:43 PM   #1
99 mustang gt help
I'm having 2 Problems I just put Another stock 4.6 in my car .I Bought the car with a Seized motor. When pushing in the Clutch Paddle the clutch doesn't fully Disengage is there a way to Adjust it ??? And I have to spay starting Fluid to get it to start then it will run on it own fine but when hitting the gas the car just dies???
derrickk is offline   Reply With Quote
Old 04-07-2013, 09:45 PM   #2
Robbiemustang96's Avatar
1st problem: probably there is one under the near the bell housing 2nd problem is probably your fuel pump
Robbiemustang96 is offline   Reply With Quote
Old 04-08-2013, 09:16 PM   #3
1996mustang's Avatar
Problem 2 could be a fuel pump however not aleayd. Could be the dri er module or maybe f/p doesnt see tge voltage increase when opening the throttle wider however could also be a maf sensor as well.
Old 04-17-2013, 05:01 PM   #4
If I pump the gas it well hit 6 grand
Old 04-17-2013, 05:10 PM   #5
And u can't adjust the clutch on the year it's self adjusting so idk
Old 04-17-2013, 05:51 PM   #6
cliffyk's Avatar
The clutch control has semi-automatic adjuster. It is described in the owner's manual (download one here) and can be manually tweaked as described here.
04:07 PM
