Wtf is this noise? - Mustang Evolution
Old 04-09-2013, 04:47 PM   #1
35th GT's Avatar
Wtf is this noise?
Watch.. It's not the shocks
http://youtu.be/SLWUn7lM1hc
35th GT is offline   Reply With Quote
Old 04-09-2013, 07:08 PM   #2
Cornkush's Avatar
Springs missing isos?
Cornkush is offline   Reply With Quote
Old 04-09-2013, 07:26 PM   #3
35th GT's Avatar
No but I was pissed after spending 4 hours putting in bushings and it didn't fix it.. Could the spring isolators be bad?
Old 04-09-2013, 11:26 PM   #4
99mustang99's Avatar
Sounds like rubber against metal.. Umm i really dont know what it could be
99mustang99 is offline   Reply With Quote
Old 04-09-2013, 11:30 PM   #5
1slosix's Avatar
check the shock bushings...not the shocks themselves but the bushings under the carpeting in the trunk and under the car
carving corners like a boss
Old 04-10-2013, 12:24 AM   #6
35th GT's Avatar
I tested that ... I unhooked the shocks and it still squeaked
Old 04-10-2013, 12:26 AM   #7
1slosix's Avatar
exhaust hanger bushings? they could be worn out where the tail pipes are held on at
Old 04-10-2013, 12:38 AM   #8
Cornkush's Avatar
The iso as in spring isolator the rubber between the spring and where it seats. Should be something on top and bottom.
Old 04-10-2013, 08:06 AM   #9
1996mustang's Avatar
could it be the quadrashocks? have you removed those and checked to see if it was them?
Old 04-10-2013, 08:28 AM   #10
35th GT's Avatar
If I put the back seats down and drive down the road it's really loud in the truck.. I haven't tested those shocks yet just the main ones.. If its that loud in the truck it's got to be the springs huh?
Old 04-10-2013, 08:35 AM   #11
It could be exhaust hangers?? The rubber pieces in them
Old 04-10-2013, 08:44 AM   #12
Foxone's Avatar
I have the same sound, I havnt gotten around to searching for it though. It really sounds like shock bushings to me. The quadrashocks could be the culprit. Might try some wd40 on the bushings and let it soak in.
Foxone is offline   Reply With Quote
Old 04-10-2013, 08:58 AM   #13
35th GT's Avatar
Ill try that.. Ill let you know if it works thanks
---------- Post added at 08:57 AM ---------- Previous post was at 08:55 AM ----------
Nah I looked and the sound is coming higher and lower those shocks
---------- Post added at 08:58 AM ---------- Previous post was at 08:57 AM ----------
Than*
Old 04-10-2013, 09:02 AM   #14
Foxone's Avatar
So really, if its higher, what else is up there? just the shock bushings that go through the body. Weirdness.
Old 04-10-2013, 09:11 AM   #15
35th GT's Avatar
Yeah but when I unhooked the main shock from the axle it still squeaked so I'm guessing the springs are bad.. I'd hate to get lowering springs because I have a procharger kit on the car and it rides 5 inches from the ground so any lower It'd get damaged
Old 04-10-2013, 09:35 AM   #16
Foxone's Avatar
Then you just need new isolators, those are cheap.
Old 04-10-2013, 10:12 AM   #17
Voltage258's Avatar
Region: Utah
Sounds like sway bar bushings. Spray them with white lithium grease and see if it helps. And don't use wd40 it dries the bushings out I think.
If your getting good gas mileage, your not having fun.
Voltage258 is offline   Reply With Quote
Old 04-10-2013, 03:06 PM   #18
fastmustangs1's Avatar
Did u check the Upper control arm bushings as well. The rubber bushing will dry out and squeek with time. Id check those too.
Here are pics of my uppers.
fastmustangs1 is offline   Reply With Quote
Old 04-10-2013, 03:22 PM   #19
Foxone's Avatar
Doh, I forgot about those, and they are higher up, could be it.
Old 04-10-2013, 03:27 PM   #20
Your car would just have a single UCA right on the pumpkin lol.
Old 04-10-2013, 03:35 PM   #21
Foxone's Avatar
My 01 has the same sound, If 35th GT finds it, Ill send him some beer for all the hard work.
Old 04-10-2013, 03:35 PM   #22
35th GT's Avatar
No I haven't checked those but I will
Old 04-10-2013, 03:42 PM   #23
send me one too.
Old 04-10-2013, 03:44 PM   #24
35th GT's Avatar
It's got to be the springs.. It's closer to the wheels and more towards the doors to be upper bushings or the shocks
Old 04-10-2013, 03:49 PM   #25
I would check just to make sure.
Old 04-10-2013, 03:57 PM   #26
Foxone's Avatar
I dunno, the springs really dont move around much, but when you squash the rear end down like in your video your pivoting those arms, and they connect right up behind the trunk, explains why its so loud. Easy check would be to unbolt the axle side pop the arm up out of the way and try making the sound again. Wont hurt it to disconnect it just for that, wouldnt drive it like that obviously. Times like this is when I wish I had one of those stethoscopes (Probably spelled wrong) you cold put it right on each part and hear the squeek.
here is a link to the bushings, Im probably gonna get a couple sets soon.
Prothane Mustang Rear Upper Axle Bushings (79-04 All, Excludes IRS) 6-309-BL - Free Shipping!
Old 04-10-2013, 04:02 PM   #27
Gera8712's Avatar
My cousin has the same noise on his magnum and we checked and lubricated EVERY single bushing on his car and the noise is still there
And guess what he has no isos on his Eibach pro kit.. Si that's gotta b it!
Gera8712 is offline   Reply With Quote
Old 04-12-2013, 09:13 AM   #28
Cornkush's Avatar
How long ago did I suggest isos...
Old 05-05-2013, 09:14 AM   #29
35th GT's Avatar
It's the rear upper control arms!!! Finally found the problem! I greased the crap out of both of them and the sound muted some but not enough, so I'm going to replace the whole thing
Old 05-06-2013, 08:55 AM   #30
Foxone's Avatar
Kick *** man, Ill be doing the same soon.
11:31 AM
