Help ajusting head lights - Mustang Evolution
Old 04-09-2013, 10:16 PM   #1
Allans03ragtop's Avatar
I bought new head lights and bulbs when I did my make over and I can't get my head light to adjust up. They are aiming very low. I am running them on high beam and no one is high beaming me back that is how low they are pointing.
03 Sonic Blue CONVERTIBLE W/STYLE BAR AND SPEEDSTER COVER AND 18X10W/275/35 REAR AND 18X9W/245/45 FRONT. OFF ROAD X-PIPE 40 SIERIES FLOMASTERS AND CAI.
Allans03ragtop is offline   Reply With Quote
Old 04-10-2013, 04:56 AM   #2
Is there another way to adjust them besides the screw on the top that adjust them, or could it be the bulbs themselves.
Old 04-15-2013, 03:43 PM   #3
BigB227's Avatar
I'm having the same problem as you so hopefully someone chimes in!!
BigB227 is offline   Reply With Quote
Old 04-15-2013, 03:47 PM   #4
deadsp0t's Avatar
I adjusted mine with that screw
That's unimpressive
Old 04-15-2013, 03:50 PM   #5
BigB227's Avatar
I used the screw on the back of the housing but it didn't seem like it really made a difference
Old 04-15-2013, 03:54 PM   #6
deadsp0t's Avatar
I used a wall to see where it's at, took 3x trial and error.. Have it perfect for me now
That's unimpressive
Old 04-15-2013, 04:17 PM   #7
Count Dragula's Avatar
It's not the screw on the back. It's the screw on the top
2007 Mustang Gt
2.3L Whipple Supercharger
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 04-15-2013, 09:50 PM   #8
R6man's Avatar
There's a screw on top. It's a Philips. Get ur car as close to a wall as u can and take some masking tap and put it in the center of the light beam on the wall. Back your car off 25 feet and adjust the beam back on the cross u made earlier. I believe u loosen the screw to raise the beam. U will see it move
R6man is offline   Reply With Quote
Old 04-15-2013, 10:02 PM   #9
If you have the owners manual for the car, there are some precise instructions for adjusting the headlamps.
Old 04-15-2013, 10:13 PM   #10
Thanks guys I figured it out. I was using the the Phillips head screw but it was not doing anything. I tried it again and turned it until it stopped then reversed the direction and it started moving the beam on the wall. So if you are having this problem try turning it until it bottoms out the it should start working.
09:16 AM
