pi head help - Mustang Evolution
Old 04-10-2013, 08:03 AM   #1
98GTCONV's Avatar
pi head help
Im looking to buy these for my pi swap:
Ebay item # 261196781541
Are these the heads with the 11 bolt valve covers? If not, will they still work in my application?
98GTCONV is offline   Reply With Quote
Old 04-10-2013, 10:27 AM   #2
98GTCONV's Avatar
Anybody?
Old 04-10-2013, 01:45 PM   #3
98GTCONV's Avatar
Great info guys
Old 04-10-2013, 02:57 PM   #4
1996mustang's Avatar
Gimme a few ill let u know imma copy and paste it now to have a look but i got Windsor heads so 13/14 bolts mine ill let u know soon
Old 04-10-2013, 03:48 PM   #5
98GTCONV's Avatar
Thank you!!
Old 04-10-2013, 09:35 PM   #6
11 bolt or 13/14 bolts will work on any pi swap application, im sorry i couldnt answer earlier im a tech at pepboys and sometimes i get caught up in the job, but i saw they sold, and by counting the bolts on the sides i would have said looked like the 11 bolt pattern of the romeos, but either or head would have worked on your application.
Old 04-10-2013, 09:37 PM   #7
98GTCONV's Avatar
Ok good. I just bought them off ebay along with the head swap kit from AM. Is there anything else (specifically) that I need? I have everything for the manifold as well (water pump nipple, alt bracket, etc.)
Thanks again
Old 04-10-2013, 09:53 PM   #8
your goin to need the crossover pipe that runs under the intake manifold for the heater, if the heads are romeo heads the timing cover may differ from the windsor i cant remember so i would suggest running the timing cover applicable to the heads. its a suggestion and may not make a difference but its something i will have to research or you can research as well. thats it for now off the top of my head.
Old 04-10-2013, 09:59 PM   #9
98GTCONV's Avatar
The aluminum crossover on the manifold? Or something else?
---------- Post added at 11:59 PM ---------- Previous post was at 11:59 PM ----------
Oh nvm I read that wrong. Do you know a part number for that?
Old 04-10-2013, 10:09 PM   #10
Heater Hoses - B - 4.6 SOHC EFI (09/18/00...05/12/04). Fits: Mustang | Wholesale Ford Parts
website shows the crossover pipe part number 18863 trying to get the oem number now
Old 04-10-2013, 10:50 PM   #11
98GTCONV's Avatar
I think I've got that hose.
What's the easiest way to tell if I have Windsor or Romeo heads?
Old 04-11-2013, 06:36 AM   #12
Mzilla's Avatar
You need to count the number of bolts that hold the valve cover to the head. 11 bolts = Romeo 13/14 bolts = Windsor. Ford also revised the Romeo heads for the 2004 model year and added additional threads for the spark plug holes. If you are going forced induction and plan on making more than 12 pounds of boost i would highly recommend the 8 thread count 04 Romeo heads. These heads are not prone for the plugs blowing out I them.
Mzilla is offline   Reply With Quote
Old 07-16-2016, 11:59 AM   #13
mustang sammy's Avatar
I have 99 heads off an expedition and they're 11 bolt. Everyone keeps telling me they're Windsor.
Sent from my SGH-T599N using Mustang Evolution mobile app
mustang sammy is offline   Reply With Quote
Old 07-16-2016, 12:01 PM   #14
Heads
04:15 AM
