Lowering - Mustang Evolution
Old 04-10-2013, 10:25 AM   #1
Warbot's Avatar
Lowering
Wondering what the lowest coilovers are im already lowered 2inches in the front and 2.5inches in the rear with my tein s techs but i want like another 1 inch drop any ideas ive thought of cutting but idk yet.
Warbot is offline   Reply With Quote
Old 04-10-2013, 11:41 AM   #2
Region: Arkansas
3" is SLAMMED. you'll bottom out on pebbles in the road lol.
I really don't know of any springs that sit that low.
BackPressure is offline   Reply With Quote
Old 04-10-2013, 11:52 AM   #3
1slosix's Avatar
you can get 3" with cut lowering springs...here's cut eibach sport lines on a friends car...his LTs did not like it lol
carving corners like a boss
Old 04-10-2013, 11:53 AM   #4
Venomouz831's Avatar
My front coilovers on my gt were able to go as low as 3' and on the back 2.8' but of you want lower just cut a little bit off
)02 Gt, Founder of WE2G
Old 04-10-2013, 11:55 AM   #5
99mustang99's Avatar
Mine was that low and they look sooooo sexy that low!! I wish the bodys on the car could actually handle to be that low tho://
99mustang99 is offline   Reply With Quote
Old 04-10-2013, 12:14 PM   #6
fastmustangs1's Avatar
You will run into geometry issues if u lower the ride height excessively. Issues like bump travel with shocks, bump steer issues etc. IMO 2 in drop is the max I would recommend running.
fastmustangs1 is offline   Reply With Quote
Old 04-10-2013, 02:52 PM   #7
Warbot's Avatar
Thats looks sick!
---------- Post added at 02:52 PM ---------- Previous post was at 02:52 PM ----------
What coilovers did you have?
Old 04-10-2013, 03:11 PM   #8
Griggs racing up front and koni's in the back
Old 04-10-2013, 04:08 PM   #9
Gera8712's Avatar
How mach of the spring did he chop off do you know?
I have the pro kit I'm my 04 GT but it's not low enough to me
Gera8712 is offline   Reply With Quote
Old 04-10-2013, 04:09 PM   #10
Do one coil at a time, that should give you a good drop
Old 04-10-2013, 09:21 PM   #11
1lowGT's Avatar
Hey man. Lol. If you cut them or go any lower you're gonna be effed with speed bumps. Especially if you dd your car.
Old 04-10-2013, 09:22 PM   #12
1slosix's Avatar
i think a coil and a half but i'd just do 1 and see where it sits
Old 04-11-2013, 01:52 PM   #13
Warbot's Avatar
Yeah idk if i will yet haha my exhaust already scrapes sometimes.
Old 04-12-2013, 09:59 AM   #14
1lowGT's Avatar
So does mine, and you're lower than me. You should get some stock mach 1 springs and cut them, Aslow4v done that and his car is slammed.
Old 04-15-2013, 06:22 PM   #15
MidnightBlueGT's Avatar
It'd look sick, but drivability would be an issue unless u live were there are perfect roads everywhere...wish all mine were and id lower a good bit
Old 04-15-2013, 08:48 PM   #16
R6man's Avatar
Can I take these spacer things out. What will happen. And What's best way to get them out
R6man is offline   Reply With Quote
Old 04-15-2013, 11:12 PM   #17
1lowGT's Avatar
Jack your car up and pull em out? Idk about those things.
Old 04-16-2013, 05:19 PM   #18
R6man's Avatar
I hate to take them out and not be able to put them back in
Old 04-16-2013, 05:39 PM   #19
It will be easier to put back in because if you cut them then they will be shorter and will fit in the space easier.
Old 04-21-2013, 11:02 PM   #20
Why not just save for a good set of lowering springs instead of cutting them.
Old 04-21-2013, 11:36 PM   #21
DaBluedude's Avatar
Get a high quality spring. The handling will be better. Imo, you should keep the idolaters or you will cause premature wear on the spring and a arm. As for removal, get a big Crow bar, stand on the end of the spindle and gently but firmly slop the old spring out. Getting the new spring in is a *****. I seated the top the got it in position. Then with a big *** bar slip it into the a arm. My eibach pro kit springs were actually about 1/8" taller overall than my mach 1 springs but it has settled to about 2/3" lower. I have all isolators in. Oh and forget poly bushings unless you like the sound of mice squeaking all day long. I got a 6' length of coolant hose (3/4" inner diameter) and cut it as new hose. (use poly grease and silicone spray to get it on the spring. About 6$ vs 50 for new stock rubber ones.
2003 Mach 1
12:52 AM
