03 fuel rail - Mustang Evolution
Old 04-11-2013, 07:10 PM   #1
Xaperez100's Avatar
03 fuel rail
Anyone know where the fuel pressure release valve is at on it? 03 gt
Xaperez100 is offline   Reply With Quote
Old 04-11-2013, 07:21 PM   #2
Rejekt's Avatar
FORD:
2002 TAURUS
2003 CROWN VICTORIA, MUSTANGLINCOLN:
2003 TOWN CARMERCURY:
2002 SABLE
2003 GRAND MARQUIS
Article 02-11-1 is being republished in its entirety to update the model year coverage. ISSUE:
2002 Taurus/Sable vehicles equipped with the 3.0L 2V built after 4/8/2002 and vehicles equipped with the 3.0L 4V Duratec built after 5/8/2002, 2003 Crown Victoria/Grand Marquis/Mercury Marauder and Lincoln Town Car equipped with 4.6L 2V/4V built after 09/15/2002, and 2003 Mustang equipped 3.8 & 4.6 2V/4V built after 09/15/02, will no longer have the Fuel Pressure Relief Valve (Schrader Valve).
ACTION:
To relieve or manually check fuel pressures, refer to the following Service Procedures for details.
SERVICE PROCEDURE
Service Procedure For Relieving Fuel Pressure
  1. Remove the fuel pump relay or fuse in the engine compartment fuse box, refer to chart listed in this TSB for fuse location.
  2. Start the engine and allow idling until the engine stalls.
  3. After the engine stalls, crank the engine for approximately five seconds to ensure the fuel injection supply manifold pressure has been released.
  4. When fuel system service is complete, install fuel pump relay or fuse.
  5. Cycle key and wait 3 seconds to re-pressurize the fuel system. Check for leaks before starting engine.
    NOTE:IT MAY TAKE MORE THAN ONE KEY CYCLE TO RE-PRESSURIZE THE FUEL SYSTEM.
  6. Start engine and check for leaks.
    NOTE:IT IS POSSIBLE THAT A DTC MAY BE SET DUE TO THE PUMP RELAY BEING PULLED AND THE ENGINE STARTED AND RUN OUT OF FUEL. IF DTC'S ARE SET, CLEAR ALL DTC'S BEFORE RETURNING VEHICLE TO THE CUSTOMER.
Service Procedure For Manually Checking Fuel Pressure With A Gauge
  1. Remove the fuel pump relay or fuse in the engine compartment fuse box. Refer to chart listed in this TSB for fuse location.
  3. After the engine stalls, crank the engine for approximately five seconds to make sure the fuel injection supply manifold pressure has been released.
  4. Disconnect fuel line at the fuel rail to chassis line pierce point, using special service tool number 310-D005 or equivalent.
  5. Install schrader valve service port adaptor (adaptor spring lock coupling), refer to chart listed in this TSB for service tool number.
  6. Install fuel pressure gage special service tool 310-012 or equivalent.
  7. Install fuel pump relay or fuse.
  8. Cycle key and wait 3 seconds to re-pressurize the fuel system. Check for leaks before starting engine.
  9. Start and run engine to purge air from fuel system (Air trapped in the fuel system may effect test results).
  10. Perform normal diagnostics and service repairs as needed.
  11. After fuel system service is complete, relieve fuel system pressure using fuel pressure gauge relief valve.
  12. Remove special service tools.
  13. Re-connect fuel system lines.
  14. Cycle key and wait 3 seconds to re-pressurize the fuel system. Check for leaks before starting engine.
  15. Start engine and check for leaks.
    FUEL VALVE SERVICE PORT ADAPTOR CHARTVehicleModel YearEngineTool NumberFuel Pump Relay Location (Engine Compartment Fuse Box)Fuel Pump Fuse Location (Engine Compartment Fuse Box)Taurus/Sable20023.0L 4V310-D003, 310-100"K-4"/C1051 Taurus/Sable20023.0L 2V310-D003"K-4"/C1051 Mustang2003All310-100 F1.14Crown Victoria20034.6L 2V310-100"11-1"/C1051 Grand Marquis20034.6L 2V310-100"11-1"/C1051 Town Car20034.6L 2V310-100"11-1"/C1051 Mercury Marauder20034.6L 4V310-100"11-1"/C1051
SUPERSEDES:
02-11-1
Rejekt is offline   Reply With Quote
Old 04-12-2013, 10:44 AM   #3
cliffyk's Avatar
^+1,
Yup, there isn't one on the 2003 through 2004 Mustangs...
Old 04-12-2013, 02:52 PM   #4
Xaperez100's Avatar
Originally Posted by cliffyk View Post
^+1,
Damn
10:25 PM
