Quick question - Mustang Evolution
Old 04-12-2013, 04:41 PM   #1
Rich04's Avatar
Quick question
I just recently put the stock headlights on how do i adjust them? It seems they are aimed up
Rich04 is offline   Reply With Quote
Old 04-12-2013, 04:45 PM   #2
Count Dragula's Avatar
There is a screw on top of them. Just turn it to angle them up or down
---------- Post added at 06:45 PM ---------- Previous post was at 06:43 PM ----------
Get up next to a wall and turn them on and make them level. Then back up 20 feet and do it again
2007 Mustang Gt
2.3L Whipple Supercharger
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 04-12-2013, 04:46 PM   #3
Rich04's Avatar
It looks more like an Allen key fitting and i was turning it and it didn't seem to do much
Old 04-12-2013, 04:47 PM   #4
Mine looked like an Allen key too but you can use a Phillips on mine. Mine also has that down in it. But that screw is what angles them
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 04-12-2013, 10:32 PM   #5
Damn this reminded me that i need to adjust mine also since i just got new headlights, They are practically not even aimed at the road i've noticed lol.
Old 04-12-2013, 10:38 PM   #6
Polar Bear's Avatar
Region: Asia
I've got the Raxiom and although they look great the adjustment is very limited.
Steve
Polar Bear is offline   Reply With Quote
Old 04-14-2013, 09:19 PM   #7
Allans03ragtop's Avatar
You may have to turn the screw till it stops then start turning it the other way and it should start adjusting them.
That is what I had to do when I put new ones on mine. They did not move until I did that. Be sure you are sitting level when you do this. You can use any wall.
---------- Post added at 11:19 PM ---------- Previous post was at 11:18 PM ----------
And a Phillips screw driver will do it.
03 Sonic Blue CONVERTIBLE W/STYLE BAR AND SPEEDSTER COVER AND 18X10W/275/35 REAR AND 18X9W/245/45 FRONT. OFF ROAD X-PIPE 40 SIERIES FLOMASTERS AND CAI.
Allans03ragtop is offline   Reply With Quote
Old 04-14-2013, 09:24 PM   #8
DaBluedude's Avatar
^this. That or take the housing out and make sure the ball and socket is seated for the adjuster properly. My new headlights wernt so the adjustment screw did nothing. I has to pop the adjuster in place by pulling the chrome housing towards the back of the headlight where the adjuster is located. There was a definite pop and then everything was good. I bet this would happen if I had adjusted the headlight all the way down too though.
2003 Mach 1
01:12 AM
