2nd gear grinds when rev are high? - Mustang Evolution
Old 04-13-2013, 07:06 PM   #1
Xavier9370's Avatar
My second gear started giving me grinds if i try to shift after high revs or wot. What could it be guys?
2004 gt
Xavier9370 is offline   Reply With Quote
Old 04-13-2013, 07:53 PM   #2
Kstangs2002's Avatar
Sounds like bad syncro mine did the same but on 3rd had to get it rebiult
Kstangs2002 is offline   Reply With Quote
Old 04-13-2013, 08:03 PM   #3
Xavier9370's Avatar
Is that fix able? And how much usually?
Old 04-13-2013, 09:51 PM   #4
It's fixable, but like kstangs said its a tranny rebuild
Old 04-13-2013, 10:00 PM   #5
1slosix's Avatar
i remember when my GT started doing that...get ready for a rebuild. i'd do it before you take anything else with you
carving corners like a boss
Old 04-14-2013, 12:20 AM   #6
I paid about $250 on parts and $100 on labor i know the guy so he charged me real cheap till now works great getting my TOB replaced and get my clutch monday ordered my parts at AM ford racing TOB and pilot bearing so his going to drop the trans again labor is cheap though others would charge between $450-$500 in my area just labor wise
Old 04-14-2013, 06:32 AM   #7
Xavier9370's Avatar
Anyone. Recommends anyone in central Florida for the job? I will not ever go to power by ford ever so that one is out the list.
Old 04-14-2013, 01:09 PM   #8
cliffyk's Avatar
You may want to try changing the transmission fluid and loading only 3.0 L (3.2 qts) of fluid--I recommend Mobil 1 ATF.
There is a TSB describing the problem (TSB-04-26-13), which is that the factory and owner's manual recommendation of using 3.8 L (4.0 qts) is too much.
This caused windage problems, with the excess lube causing the gears to over-synchronize because the excess oil makes the fluid overheat and foam. This and affects the turning ratios of the gear train; similar to your trying to run on the beach in 2 feet of water. The increased resistance to turning slows the gears prematurely and alters the synchronizer timing, causing shift problems. The oil level was reduced to 3 liters and the problem was resolved.
Reducing the fluid level, and using the M1 ATF, can help or even correct the problem if no severe damage has been done...
Old 04-14-2013, 06:37 PM   #9
Excellent bit of info, as usual, Cliffy.
Old 04-15-2013, 05:32 AM   #10
Xavier9370's Avatar
Awesome information, thanks a bunch. I am going to try that first to see i will update later
Old 04-15-2013, 07:57 AM   #11
1slosix's Avatar
Id swap a qrt of fluid for a qrt of syncromesh..it did help when i had that issue. But he is right 3.25 qrts is the correct amount.
Old 04-15-2013, 08:15 AM   #12
TruChris's Avatar
Could be clutch. My friend had same problem and we thought it was synchrob but it was the clutch... Does it seems easy to push down, like no pressures to it?
TruChris is offline   Reply With Quote
Old 04-15-2013, 08:26 AM   #13
Xavier9370's Avatar
If the revs are over 3k it wont go in and make vibration with grinding sound. If revs are under 3k is normal like nothing is wrong, i like shifting higher than 3k even when cruising it just sounds better and feels right
Old 04-15-2013, 08:43 AM   #14
cliffyk's Avatar
That is exactly the issue addressed in the TSB. There is a similar TSB (TSB 04-15-6) for the 2001 through 2003 model years...
Old 04-15-2013, 08:53 AM   #15
Xavier9370's Avatar
Yes thats exactly it. Nice thanks a bunch
Old 04-15-2013, 08:57 AM   #16
TruChris's Avatar
Im pretty sure its clutch, thats the same thing with my friends civic except it was 3rd gear and he had to drive slow .
---------- Post added at 08:57 AM ---------- Previous post was at 08:55 AM ----------
Oh i just saw the link, but goodluck with the fix!
Old 04-15-2013, 09:02 AM   #17
Xavier9370's Avatar
Nextweek i will take it to the shop to what happens
---------- Post added at 10:02 AM ---------- Previous post was at 10:01 AM ----------
To see what happens.
Old 01-18-2014, 10:03 PM   #18
escottcarp's Avatar
Is Mobile 1 ATF and MERCON the same type fluid?
escottcarp is offline   Reply With Quote
Old 01-18-2014, 10:24 PM   #19
Yep. They'll both work.
Old 01-18-2014, 10:49 PM   #20
cliffyk's Avatar
They meet the same basic specification, however they do not perform the same--use the M1, you will not regret it...
Old 01-18-2014, 10:56 PM   #21
Reminds me. I need to change mine...
Old 01-19-2014, 08:26 AM   #22
escottcarp's Avatar
Thanks for the info.
I saw a post about a 3650 that felt 'notchy.' Mine feels like that this year in the cold temps. After a little research I found several posts and articles about MERCON ATF. If ATF stands for automatic transmission fluid, it is difficult to understand why I would put that in my manual transmission rather than a gear lube. Some drivers suggest synthetic and others say don't use synthetic. My owners manual says to use MERCON, also. The TSB says to only put 3 liters in the gearbox. Id rather understand the instructions rather than just follow them, if you know what I mean. I was wondering if I missed something until I saw this particular post and then referenced the TSB.
Thanks for the M1 advice!
Old 01-19-2014, 10:17 AM   #23
cliffyk's Avatar
You would put ATF in your 3650 transmission because that is what Ford recommends, and more importantly because it is what Tremec--the company that manufactured the transmission--designed it to use.
This is from the Tremec 3650 service manual:
Old 03-12-2014, 06:20 PM   #24
shawn.velez36's Avatar
I have this same problem but mines doing it in 3rd and 4th.... Hoping I don't have to drop a whole bunch of money on it. ;(
shawn.velez36 is offline   Reply With Quote
Old 03-12-2014, 07:33 PM   #25
Lol.
I was just thinking about this thread but I've been too busy to go look for it.
I was at an autocross last weekend and thought I was going to grind second gear perfectly round before the day was through... Embarassing!... No, I still had not ever changed the transmission fluid since purchasing the car a year ago. I needed no further reminders. It was full of metal shavings (hope they weren't all mine!) and looked like it had never been changed. It was slightly over filled as well.
I refilled with 3.25 quarts of Mobil 1 synthetic, as Cliffy suggested, and it seems to have cured the problem.
It shifts noticeably smoother now...
Old 03-12-2014, 07:51 PM   #26
My T-45 does this going from 1st to 2nd. Used to do it from 2nd to 3rd but fresh fluid cured that. Still, time for a new trans. I'm in KY right now but by the end of the month a fresh 3650 is going in with 3.2qts of Syncrhomesh.
Another thing to look at is your shifter. No joke, if you have an aftermarket shifter in there from a previous owner and he/she set the stops (or you did) that is a very bad thing in a 3650. The 3650 has internal stops and you do NOT use shifter stops. Doing so can potentially cause it to not engage into gear fully. The second hand 3650 Tri-Ax I got to put in my new trans has stops and they are definitely set. I'm just removing them before it even goes near the trans...
Old 03-12-2014, 08:16 PM   #27
V6 stang's Avatar
I was going to make a thread on this but I will just hijack this..
Mine grinds from first to second, but only when it's cold. When my trans warms up it shifts nicely. My trans also clunks when going into first. Clutch will need replaced prolly in 15-30k miles, but it shouldn't be my clutch. I planned on swapping fluid out this weekend with Mobil1 ATF synthetic to see if it will correct my problem or at least make it a little better. Where do I grab this fluid at?
2012 Mustang GT Convertible
Roush Exhaust
2003 Mustang GT (Sold)
Old 03-12-2014, 08:59 PM   #28
Any box store sells it or just order it online. You have a typical 3650 issue and likely is the fluid being overfilled from the factory spec or the owners manual being followed by a previous owner. 3.2 qts is the correct amount.
Old 03-12-2014, 10:34 PM   #29
V6 stang's Avatar
Box store? I thought I saw it at autozone but that might have been oil
Roush Exhaust
Old 03-12-2014, 11:50 PM   #30
AutoZone has it.
Old 03-13-2014, 06:41 AM   #31
Box store=brick and mortar store
Sent from my VS980 4G using Mustang Evolution mobile app
08:12 PM
