hope i didnt mess up - Mustang Evolution
Old 04-14-2013, 06:03 PM   #1
I decided to clean my engine today so I sprayed it down with foaming cleaner let it sit and sprayed it with my pressure washer. I used the delicate tip for the washer and made quick passes across the engine. Before I did this my battery light had been on since my alt. Went bad. When I started the car the battery light was off but the abs light was on. I figures I got water somewhere so I let it sit awhile. When I started it the abs light was still on so I let it run awhile and the light started flickering and would go off if I turned the headlights on. Eventually it went off so I guess the plug dried out. But now my battery gauge is pegged out y'all think this is a wet plug also? I also changed my rear caliper out today. What y'all think?
Cdbformula is offline   Reply With Quote
Old 04-14-2013, 06:09 PM   #2
Out being: no juice or the other side?
Old 04-14-2013, 06:13 PM   #3
DaBluedude's Avatar
The abs sensor is likely linked to the caliper issue. The abs module is part of the brake fluid system. Is it possible you got a air bubble in the system.
2003 Mach 1
Old 04-14-2013, 06:23 PM   #4
The battery gauge is showing overcharging now.
Old 04-14-2013, 08:09 PM   #5
1slosix's Avatar
well you said the alt went bad...was it replaced? also just for future spraying..i cover my alt, battery, and coil pack with either plastic bags or aluminum foil...i can clean them with a towel and some spray detailer
carving corners like a boss
Old 04-14-2013, 08:11 PM   #6
Yes I changed the alt.
Old 04-14-2013, 08:16 PM   #7
1slosix's Avatar
i'd have the charging system tested when you get a chance...as long as the CEL doesn't come on or you don't notice a miss i'd say you're golden for the most part
Old 04-14-2013, 09:31 PM   #8
I used engine degreaser on my car yesterday, i covered the alternator and battery with plastic bags first though.
Old 04-15-2013, 07:53 PM   #9
Yeah next time I will cover stuff up. Everything is back to normal now. Except my hrater core blew up on the way home. I changed it a few months ago and didnt use a ford replacement and now I gotta pay the price lol.
Old 04-15-2013, 08:09 PM   #10
DaBluedude's Avatar
Ouch. That is my least favourite fix job ever.
2003 Mach 1
Old 04-15-2013, 08:59 PM   #11
Yeah ima bypass it tomorrow till I feel like pulling the dash again.
Old 04-15-2013, 10:09 PM   #12
Lorraine's driver
ab_mach1's Avatar
Lol, unanimous among all stangers.
Instagram: @ab_mach1
Old 04-15-2013, 10:14 PM   #13
Lorraine's driver
ab_mach1's Avatar
I had a buddy do this once to his engine bay. He had electrical issues for a week. Over that next weekend I brought my shop vac over and vac'd every electrical connection we could find. It took a few hours, but that seemed to help. Also, if you have an air compressor, maybe you could blow out areas you can reach on your alternator. Hope that helps.
04:18 AM
