Need help - Mustang Evolution
Old 04-16-2013, 02:20 AM   #1
GP3GT's Avatar
Need help
So I've been hearing noises with my rear end still.. When I accelerate it makes a low whine in the rear.. And also when I brake and then push the gas again it makes a creaking noise in the rear.. I changed the rear diff fluid and added the friction modifier.. I had jiffy lube do it.. Changing the fluid didnt make the noise go away like I thought it would.. Anyone have had this happen to them before? It's a 99 gt auto btw
95 Camaro- Sold
99 Camaro Z28- Sold
99 Mustang GT- DD
GP3GT is offline   Reply With Quote
Old 04-16-2013, 02:24 AM   #2
Venomouz831's Avatar
So it's coming from the rear end? Or maybe a wheel? I had something similar and it turned out to be my wheel bearing
)02 Gt, Founder of WE2G
Old 04-16-2013, 02:27 AM   #3
GP3GT's Avatar
Yeah the whine and creaking are both coming from the rear end.. On acceleration it whines, and it also creaks when I'm braking.. It's been going on for a while but I wana take care of it because I hate when I feel something is wrong with my car lol..
95 Camaro- Sold
99 Camaro Z28- Sold
99 Mustang GT- DD
Old 04-16-2013, 02:34 AM   #4
Speed_Mister's Avatar
Region: Arkansas
Both are normal. i have creaking noises in my rear end and I hear it better when I hit my car and the started after my install of axles and differential. The whining is your gears, the depth of the pinion and final gear that they have connecting each other sometimes create a whining noise worse than other cars or maybe become worse due to more friction with each other making them dig into each other a little or rub onto each other more than normal. Not really a bad thing. Just normal wear and tear usually it goes away or you just get used to it. The creaking that your experiencing isn't bad either I suspect it's either a creaking control arm or something with your rear abs. I know what your talking about and I have the same thing that happens to me for over 20,000 miles and nothing has happened to my rear end.
2004 Mustang GT 5 Speed
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 04-16-2013, 01:01 PM   #5
GP3GT's Avatar
A co worker of mine said the whine could be from me having an aftermarket stereo and having a bad ground.. It whines as I accelerate and stops when I let off.. He said it sounds like its coming back form the rear but it's actually from the speakers in the back.. Idk if that's true or not.. But as for the creaking, it could be a lca? Is that why my take offs might be forever to get up?
95 Camaro- Sold
99 Camaro Z28- Sold
99 Mustang GT- DD
Old 04-16-2013, 01:06 PM   #6
Region: Arkansas
I've had a whine noise come from my speakers to before it was more of a different pitch of noise than from my rear end. If it sound more like a hum than a whine probably a bad ground. And no I just know that control arms mostly aftermarket control arms creak badly.
Full Bolt Ons
370rwhp 470rwtq
Old 04-16-2013, 01:07 PM   #7
I actually had that problem about the stereo whine and it was my speakers. I never got to fix it but as I would accelerate the noise would start and get a little louder.
Old 04-16-2013, 01:56 PM   #8
GP3GT's Avatar
Ok thanks guys I feel alittle better now that's it not anything major.. I'll probably still get it checked out soon just in case.
95 Camaro- Sold
99 Camaro Z28- Sold
99 Mustang GT- DD
Old 04-16-2013, 06:57 PM   #9
Could be a sticking caliper. Itll make a whining noise
Cdbformula is offline   Reply With Quote
Old 04-16-2013, 07:25 PM   #10
Mfore33's Avatar
Had the same sound in my 2000 gt it was the carrier bearing going out
11:42 AM
