Tips on installing Prochamber - Mustang Evolution
Old 04-16-2013, 02:26 PM   #1
So hopefully I'll be installing my new prochamber this weekend, any tips y'all have would be helpful.
Old 04-16-2013, 03:10 PM   #2
1slosix's Avatar
use a small trolley jack to hold it up as you bolt things down...snug up all four corners before you tighten them...it'll make things easier...oh and buy a couple passenger side manifold gaskets because they are brittle...i went through 2 or 3 before i got one to seal right
carving corners like a boss
Old 04-16-2013, 04:36 PM   #3
jjsg09's Avatar
Taking off the stock exhaust is the hardest part.
Old 04-16-2013, 04:44 PM   #4
Yea I was thinking of using the jack as a stand to hold it up. And what type of gaskets do you mean? I'm a newb at stuff like this, just give me a link or something so I can see a picture and I'll be good lol
---------- Post added at 03:44 PM ---------- Previous post was at 03:44 PM ----------
Yea I heard about that, passenger side right?
Old 04-16-2013, 07:04 PM   #5
BigB227's Avatar
Soak it in PB blaster over night and use a butane torch to heat the bolt up and give it a good pop with swivels!!!!! That's how I did it. But it was the HARDEST mod I've done
BigB227 is offline   Reply With Quote
Old 04-16-2013, 07:20 PM   #6
1slosix's Avatar
they are a lot cheaper at any autoparts
1996-04 Mustang 4.6L RH Exhaust Manifold To Mid-Pipe Gasket
Old 04-16-2013, 08:01 PM   #7
Yea I was going to PB blast it, don't have a butane torch though.
---------- Post added at 07:01 PM ---------- Previous post was at 07:01 PM ----------
Ok that's what I thought it was, just wanted to make sure.
Old 04-16-2013, 11:12 PM   #8
Oh and one more question. Would you guys recommend putting the midpipe together then bolting it up, or putting the pieces up individually?
Old 04-16-2013, 11:23 PM   #9
Tyoung68's Avatar
Jack the car up as high as you can safely its easier with more room and you can put it together but don't tighten it just so it holds together that way you can make little adjustments if you need to
Old 04-16-2013, 11:24 PM   #10
Venomouz831's Avatar
It's super easy if you have power tools, you will need an extension and a swivel would be helpful as well.
)02 Gt, Founder of WE2G
Old 04-17-2013, 08:31 AM   #11
We have power tools, what's a swivel though? We might have one and I don't know what it is.
Old 04-17-2013, 08:39 AM   #12
slow281
sixpac's Avatar
Region: Nebraska
its an adapter the makes it so you don't have to be straight on with the bolt.. kinda like and elbow looking thing.. its got a brake in the middle usally the size of a reguar socket.. just gotta make sure its a good one tend to brake when you need them the most.. ..
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 04-17-2013, 08:58 AM   #13
I'll ask my dad if we have any
Old 04-17-2013, 09:18 AM   #14
slow281
sixpac's Avatar
Region: Nebraska
2001 GT - True Blue
Old 04-17-2013, 09:42 AM   #15
Yea I've never seen those before, we probably don't have any.
Old 04-17-2013, 10:00 AM   #16
1slosix's Avatar
they are a couple bucks at any autoparts..you'll need them to get around the upper cats on the oem midpipe
Old 04-17-2013, 10:02 AM   #17
What size will I need?
Old 04-17-2013, 10:08 AM   #18
slow281
sixpac's Avatar
Region: Nebraska
I always just get the adapter that way it could be used on any socket.
2001 GT - True Blue
Old 04-17-2013, 10:22 AM   #19
I just remembered that we do have adapters, so I'll be good on that. How long of an extension would I need?
Old 04-17-2013, 10:56 AM   #20
Tyoung68's Avatar
Its like a u joint on the drive shaft
Old 04-17-2013, 12:00 PM   #21
Yea that swivel will help you alot
Old 04-17-2013, 12:20 PM   #22
I'll pick one up tomorrow then.
Old 04-17-2013, 12:21 PM   #23
Yea their like 5 bucks. Are you gonna do it piece by piece or the whole midpipe at once
Old 04-17-2013, 12:25 PM   #24
I was probably going to figure it out when I'm actually doing it, see which way will be easier.
---------- Post added at 11:25 AM ---------- Previous post was at 11:25 AM ----------
I've heard the hard part is taking the old one off.
Old 04-17-2013, 12:28 PM   #25
Yea it can be hard but use pb blaster and it should come off easy
Old 04-17-2013, 12:36 PM   #26
You think I can get it done in a weekend? I'm going to start Friday right after school, but I've got Senior Ball Saturday night so I want to get it done by then. Oh and work Sunday.
Old 04-17-2013, 12:39 PM   #27
Most definitely, my first time took me about 1 hour. After that it take me 15-20 min to take it off and put the stock one on. Shouldn't take you more than 1 hour if you have the proper tools to take off the stock midpipe
Old 04-17-2013, 12:40 PM   #28
Count Dragula's Avatar
I took my stock mid pipe off and put on an xpipe in under 30 min with out using pb blaster. I did have a high rise lift but I don't think it will be hard anyways.
2007 Mustang Gt
2.3L Whipple Supercharger
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 04-17-2013, 12:41 PM   #29
Ok good lol
Old 04-17-2013, 12:41 PM   #30
You will easily finish it before that night is over. Once it's on though drive for about 15 min or 10 miles and then tighten all bolts again
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 04-17-2013, 12:52 PM   #31
Will do.
Old 04-17-2013, 01:46 PM   #32
Mile high JDF's Avatar
I would pick up at least one spare stud just to be safe. Usually one of my studs gets goobered up when trying to take the nut off.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 04-17-2013, 01:50 PM   #33
It came with a bag of studs and nuts, I'm guessing that if something happens then I could use any of the old ones that are still good.
Old 04-17-2013, 01:52 PM   #34
Are you sure those aren't for bolting up the end that connects to the catback?
Old 04-17-2013, 02:09 PM   #35
Well there are a lot in there, I'll count them when I get home and see how many there are and how many I will need.
10:35 PM
