Brake squeak - Mustang Evolution
Old 04-16-2013, 02:47 PM   #1
98vertgt's Avatar
Brake squeak
so both my rear calipers on my car are squeaking now. only when i brake it goes away so i know it has something to do with the pads. ive taken both calipers off multiple times and lubed up the caliper slide pins but the caliper always seems to stop sliding and sticking to the rotor. ive replaced the pads twice now so im starting to think it could be the rotors causing the pads to wear uneven and jam the caliper from sliding. any input would be helpful because i cant stand a squeaking car.
98vertgt is offline   Reply With Quote
Old 04-16-2013, 02:53 PM   #2
1slosix's Avatar
did you have the rotors machined when the new pads were installed? and i know you said you lubed the slide pins but did you also lube where the pads sit in the hardware?
carving corners like a boss
Old 04-16-2013, 03:44 PM   #3
98vertgt's Avatar
No I didn't. No one around me machines drilled and slotted rotors. And no I didn't, just the pins. Should I try taking everything apart and lubing everything and get new rotors?
Old 04-16-2013, 03:50 PM   #4
1slosix's Avatar
honestly i would...
Old 04-16-2013, 03:54 PM   #5
98vertgt's Avatar
honestly i would...
I have drilled and slotted rotors right now but would just blanks be better for DD?
Old 04-16-2013, 03:55 PM   #6
1slosix's Avatar
yeah unless you're just wanting them for looks unidirectionals will be just fine...and machinable
Old 04-16-2013, 03:59 PM   #7
98vertgt's Avatar
Ok cool. I appreciate the help
Old 04-16-2013, 04:25 PM   #8
98vertgt's Avatar
I just took both wheels off and the calipers are sliding fine. However I noticed on the rotors that there's probably a quarter inch where the pad isn't making contact. Last time I tried fixing this problem both calipers were stuck and I didn't replace the pads so I'm thinking it might be the pads..
Old 04-16-2013, 04:27 PM   #9
1slosix's Avatar
easy swap at least...but if the pads are making the rotors wear uneven then it'll be an issue that'll start to follow the rotors
Old 04-16-2013, 04:36 PM   #10
98vertgt's Avatar
Ill go ahead and do both just to be safe
11:30 AM
