Traction Control? - Mustang Evolution
Old 04-19-2013, 08:24 PM   #1
Coltonhess's Avatar
Traction Control?
How exactly do I tell if my traction control is on or off? When the lights are on the button letters glow but when I push it nothing happens. Just a little confused on how you would turn it on and tell if it's on and off. Thanjs
Coltonhess is offline   Reply With Quote
Old 04-19-2013, 08:38 PM   #2
1lowGT's Avatar
Should be a little dot that lights up. It turns on when your key is off. Like if you have it turned off (dot light is on) and you turn your car off. The next time you start it it will be turned on (dot light is off)
Old 04-19-2013, 09:00 PM   #3
You can also get a tune for it. I believe BAMA's race and hybrid tune keeps it off.
Old 04-19-2013, 09:01 PM   #4
Coltonhess's Avatar
The traction light turns on when I turn the car on but disappears
Old 04-19-2013, 09:09 PM   #5
1lowGT's Avatar
It may light up when you first start it then go away. After it's running hit the button. I do it every time I go anywhere.
Old 04-19-2013, 09:12 PM   #6
Coltonhess's Avatar
I'm just confused on how you know if it's on or not. My explorers is just a button and then says traction off. I am just a little confused on how you work the darn thing
Old 04-19-2013, 09:18 PM   #7
1lowGT's Avatar
You got defrost, tc, fog light buttons?
Old 04-19-2013, 09:18 PM   #8
Mile high JDF's Avatar
Your button should light up when you turn traction control off. It should say OFF in orangeish yellow on the button itself.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 04-19-2013, 09:19 PM   #9
Coltonhess's Avatar
Yes I have all three
Old 04-19-2013, 09:23 PM   #10
1lowGT's Avatar
Fog lights will stay on all the time. Tc will turn on when car is first started. You manually turn it "off" and the light is on.
Old 04-19-2013, 09:23 PM   #11
Coltonhess's Avatar
But there all in different spots. My tc is below the radio in front of my shifter and my fog light is by my cup holder and the defrost is by my turn signal lever by the air vent
Old 04-19-2013, 09:26 PM   #12
Region: Arkansas
Traction control is ON when the LIGHT IS OFF
Traction control is OFF when the LIGHT IS ON
it's pretty backwards.
TC on in photo 1, TC off in photo 2.
ID:	103341   Click image for larger version
BackPressure is offline   Reply With Quote
Old 04-19-2013, 09:26 PM   #13
1lowGT's Avatar
Oh. Mine are all right in front of my shifter.
Old 04-19-2013, 09:31 PM   #14
Region: Arkansas
+1
I dunno wtf is up with his buttons.
Old 04-19-2013, 09:32 PM   #15
1lowGT's Avatar
Originally Posted by BackPressure View Post
+1
Yeah I do t know lol.
Old 04-19-2013, 09:34 PM   #16
On the 99-00 GTs there is only TC in front of the shifter. The Defrost is below the headlight knob and the fog lights button is just in front of the center console.
Old 04-19-2013, 09:36 PM   #17
Ubnbit's Avatar
Never heard of any defrost by a turn signal. What model is your car? Mine has a button u push. It says TCS. When u push it. It says OFF.
Old 04-19-2013, 09:36 PM   #18
Coltonhess's Avatar
I'm sorry. Lol I'm tired and just sound retarded.
Old 04-19-2013, 09:38 PM   #19
Ubnbit's Avatar
Your fine. Can you take us a pic of your tc button? It should be a matter of pushing it in.
Old 04-19-2013, 09:38 PM   #20
1lowGT's Avatar
I knew that they weren't all in front of the shifter
Old 04-19-2013, 09:40 PM   #21
Defrost
Traction control
Fog lights
It should say off right under the round part of the TC button.
Old 04-19-2013, 09:41 PM   #22
Coltonhess's Avatar
This is right. I can't right now but when I have my lights on the letters trac control glow white but when I push it it doesn't say off or anything. I'm just going to give it another try tomorrow. I think I understand now. Lol. Thanks for you guys help.
Old 04-19-2013, 09:43 PM   #23
1lowGT's Avatar
Just start your car. Have it running and push the button. Then soon the tires and see if the spinning tire light comes on in the gauge cluster. A green tire spinning is what it looks like. If you see that then tc is on.
Old 04-19-2013, 11:30 PM   #24
Zamora03's Avatar
I don't even have a tc button
Zamora03 is offline   Reply With Quote
Old 04-19-2013, 11:52 PM   #25
That means you don't have traction control lol
Old 04-20-2013, 01:10 AM   #26
2002VertGT's Avatar
Just get in your car and dump the clutch, if it Boggs down hit the TC button and dump the clutch again. If it still doesn't spin them your tv is broken
4.10 Gear/RPM thread
Old 04-20-2013, 02:56 AM   #27
Nate98stang's Avatar
Someone out a 94-98 dash and console on your car sounds like
2002 5 speed Comp Orange Mustang GT. K&N CAI,JBA headers,BBK xpipe,SLP mufflers to turn downs,Exedy stage 2 clutch,MGW short throw,drilled and and slotted roters,front:17x9 black 10th anniversary cobras Rear:17x10.5 black 10th anniversary cobras,Roush stage 3 body kit,smoked tails and side markers.
Nate98stang is offline   Reply With Quote
Old 04-20-2013, 06:07 AM   #28
Zamora03's Avatar
Mine setup is the same as his except for the tc cuz I don't have one
Old 04-20-2013, 08:05 PM   #29
Coltonhess's Avatar
Took it out this morning and the wheel light comes on and when you push the traction control button it doesn't so I think the off light is just burnt out. Thanks for the help
Old 04-20-2013, 09:52 PM   #30
Mfore33's Avatar
I have the second set of buttons cause mine is a 2000 gt. the traction control sucks it will get u killed. I just disabled mine.
Old 04-20-2013, 10:32 PM   #31
Peterzinyou's Avatar
im a bit confused as well. Have an 04, and I know on the button when it is on or off, but the green light on the gauge cluster only lights up on start up and then goes out ?????
Peterzinyou is offline   Reply With Quote
Old 04-20-2013, 10:39 PM   #32
1lowGT's Avatar
No light in the gauge cluster should be on after being started. They will all light up then go out. Now if you're talking about the green spinning wheel that only come on when tc is on and your tires spin. The tc butting in front of the shifter has to manually be pushed in to turn tc off.
Old 04-20-2013, 10:52 PM   #33
after start up the green light on the cluster is off. Will that light come on if the trac control is off?
Old 04-21-2013, 12:39 AM   #34
Coltonhess's Avatar
It will show upon starting your car and then disappear. It will only come on again if it senses wheel spin and that's when you'll see it flickering. If you push the button it should turn it off and you can spin your tires as you like
Old 04-21-2013, 02:23 PM   #35
That is the best answer ty^^^
05:46 AM
