Key fob remotes - Mustang Evolution
Old 04-20-2013, 01:24 PM   #1
Peterzinyou's Avatar
Key fob remotes
Can you only have 1 key fob remote programmed to your car at once. I bought a spare on Amazon, programmed it, it worked, and when I use the other key, that remote wont work. Am I doin something wrong?
Borla S-Type stingers, BAMA SCT tuner, K & N Typhoon CAI, Classic Design Concepts light bar, MACH 1 chin spoiler, MACH 1000 w JVC Kvw 500 HU, plastidipped hood scoop, wing & Premium GT rims, painted calipers, 3.73 gears, black Bullitt fuel door, MMD hood struts, sub-frame connectors, SVE uca & lca, Power Stop drilled/slotted rotors
Peterzinyou is offline   Reply With Quote
Old 04-20-2013, 01:59 PM   #2
I have 2 programmed to mine. Works just fine. Maybe the battery in the other died.
Old 04-20-2013, 02:04 PM   #3
I can reprogram either one, but when one is programmed, the other doesnt seem to work. I will change batts in the original to make sure, ty
Old 04-20-2013, 02:41 PM   #4
Dukieac's Avatar
I was under the impression that when you program a new one you had to program your original again. Try programming both at same time.
Dukieac is offline   Reply With Quote
Old 04-20-2013, 02:43 PM   #5
Will try that, ty
Old 04-20-2013, 03:07 PM   #6
Dukieac's Avatar
Welcome, hope it works.
Old 04-20-2013, 03:22 PM   #7
I never had to do that. I just programmed one new one when I got the car and that was it. Both work fine.
Old 04-20-2013, 03:26 PM   #8
Dukieac's Avatar
I think it depends on the new fob. The instructions that came with mine said every one would have to be reprogrammed at the same time.
Old 04-20-2013, 03:45 PM   #9
Never trief them together yet, will try when I get home, let you guys know thanks
Old 04-20-2013, 03:56 PM   #10
B52Bombardier's Avatar
I had the same problem with my '03 and F-150. Tried new batteries and didn't help. I had to do all the fobs for a car at once. Worked for both Fords!
B52Bombardier is offline   Reply With Quote
Old 04-20-2013, 09:22 PM   #11
programmed them both at once, problem solved thanks all
Old 04-21-2013, 08:52 AM   #12
Dukieac's Avatar
Good to hear.
» Members Mustangs
TOYDOS
Toydos
Pwny
BaSohol
Add your Mustang
01:13 AM
