Next mod? - Mustang Evolution
Old 04-21-2013, 09:05 PM   #1
Jheard517's Avatar
Next mod?
This summer I want to either do a vortech kit or do cams and headers first. I don't know if I should say forget the cams and headers or go straight for the kit. What do you think any advic?
Current mods
CAI
TB plenum combo
Up
Or x deleted cats SLP loud mouths
3.73 gears
Tri ax shifter
LCA
Tru trac
Tune
Jheard517 is offline   Reply With Quote
Old 04-21-2013, 09:08 PM   #2
MidnightBlueGT's Avatar
How much are you looking to spend as of right now?
Old 04-21-2013, 09:18 PM   #3
1lowGT's Avatar
Some would just skip the headers. But not sure with the vortech
Old 04-21-2013, 09:22 PM   #4
You dont really NEED headers because we have a decent manifold but its best to have long tubes. Shorties still help flow better than stock though. Its all your preferences and how smooth of a flow u want
Old 04-21-2013, 09:23 PM   #5
Slow4V's Avatar
Manifolds are very restrictive .
Shorty headers are a waste of money and time
Longtubes will help you out the most
Old 04-21-2013, 09:29 PM   #6
Jheard517's Avatar
I can spend 2400 on the cams headers install and tune. Or I can spend the 3600 on the V2 kit and then pay to have that put on and tune. Just wanna know if you had the money would you cam and headers or go for the kit? I have the money. But only for one of those this summer
Old 04-21-2013, 09:39 PM   #7
Slow4V's Avatar
Get the Vortech , building up a NA 2V is a waste of time
Old 04-21-2013, 09:42 PM   #8
Youd spend more with all the bolt ons and still wouldbt have as much power as the sc
Old 04-22-2013, 07:52 AM   #9
The modular headers/manifolds that come stock on our cars are fine we don't need new headers like the 5.0 guys do. Also longtubes aren't really needed at all with a supercharger. They sound better IMO and have a cool factor but there is a reason most Terminator guys don't upgrade them until the 600whp mark, they aren't needed.
Cams and heads are a complete waste of time/money with the stock rotating assembly unless you plan on staying NA. With a supercharger, the PI heads/cams untouched will support well over the 400-425whp the stock rotating assembly can safely take.
With what you have listed I would do:
-Subframes
-Front suspension to get rid of that 4x4 look
-S trim and fuel system to support it
-Tune
Leave the stock motor well enough alone unless you are going to pull it, forge it and THEN you can go ahead and get the PI heads ported out and drop some good cams in there to really get some more power out of it.
Old 04-23-2013, 10:17 AM   #10
Rumplemenz's Avatar
I really dont think these 2 options are even close. Vortech without question. However with that being said, you really should invest in some full length subframe connectors.
04' TR Mach 1 w/ IUP-Vortech V2 3.48" pulley-aftercooler-Anderson PP-90mm MAF-SVT pump-42lb frpp injectors-Steeda battery/trunk-frpp 4.10's-SOS Pillar w/ Ford Racing Fuel,boost/vac gauges-aluminum DS-Steeda tri ax-caster cambers-eibach damper and pro kit-MM FL subframes-borla stinger catback-17x10.5 TT-nitto 555r-04 cobra mirrors/side skirts-CDC decklid panel,billet fuel door-sequential tails-Mach 1 sills-billet antenna-MGW Mach 1 plate covers-MGW brake handle-35% tint-455 rwhp 389 tq
Rumplemenz is offline   Reply With Quote
Old 04-23-2013, 03:50 PM   #11
Jheard517's Avatar
Yeah I forgot to mention I have sub frame connectors. I just didn't know if I should get the cam and headers now then next summer add the supercharger. I just thought it would help the SC if I had them also.
Old 04-23-2013, 04:18 PM   #12
1lowGT's Avatar
It could help you now. But it just extra money you'll be spending
Old 04-23-2013, 09:18 PM   #13
Take the money you'd waste on cams, a tune to get the cams to run right and headers and buy a fuel system to support the supercharger you'll get next year.
Then next year get the supercharger kit and tune to 400/400 and roll. Headers and cams will add nothing because the rods can't really take any more than this safely.
Old 04-24-2013, 02:24 PM   #14
Jheard517's Avatar
Thanks I appreciate the help
09:07 AM
