Is my suspension off??? - Mustang Evolution
Old 04-22-2013, 09:21 AM   #1
brpfan's Avatar
I noticed this today on my way to class. I'm parked on a flat surface so neither tire is higher that the other. I did a finger test and on the rear drivers side I can get three fingers between the wheel well and the tire but the passenger side I can only fit two (snug) any ideas on what this could be? I've attached a pic of both sides
2004 Torch Red GT
Magnaflow Cat Back, Steeda Underdrives, K&N CAI, Max Motorsport Springs, Mach 1 Chin Spoiler/Grill delete
Cervinnis 3" Cobra R hood
brpfan is offline   Reply With Quote
Old 04-22-2013, 09:23 AM   #2
fastmustangs1's Avatar
maybe you got a spring sagging or your ISOs need replacing not sure.
fastmustangs1 is offline   Reply With Quote
Old 04-22-2013, 09:26 AM   #3
brpfan's Avatar
Ill have to takes look because this is bothering me now. Maybe time for an upgrade to something I want.
2004 Torch Red GT
Old 04-22-2013, 09:26 AM   #4
What springs are you running??
Old 04-22-2013, 09:29 AM   #5
brpfan's Avatar
I'm the second owner and I'm pretty sure max motorsports. I've been thinking of some eibach sport lines recently and this might do it for me
2004 Torch Red GT
Old 04-22-2013, 09:36 AM   #6
are you on stock struts and shocks too??
Old 04-22-2013, 09:41 AM   #7
brpfan's Avatar
Yes still stock.
2004 Torch Red GT
Old 04-22-2013, 09:45 AM   #8
Do you know how long you have had those springs on stock shocks, Could be shocks are going out and leaking perhaps. Check under and look at the shocks.
Old 04-22-2013, 09:47 AM   #9
brpfan's Avatar
I'm pretty sure they are stock. The previous owner said he didn't get to upgrade those. Ill get under there today and take a look. Thanks for your help bro, much appreciated
2004 Torch Red GT
Old 04-23-2013, 10:07 AM   #10
Rumplemenz's Avatar
Thats the new edge for ya... tons of people have this same issue but dont even realize it. I have the same issue. My buddy at work same issue. My old new edge same issue. LOL.. my buddies new edge down in FL SAME ISSUE.. im not kidding. One explanation is - You ever see a pic of a new edge accelerating from the dig? You will usually see the driver side front higher than the passenger. This puts more stress on the passenger side rear. Over time this causes this uneven issue.
Rumplemenz is offline   Reply With Quote
Old 04-23-2013, 04:17 PM   #11
brpfan's Avatar
Damn, so what was the fix?
2004 Torch Red GT
Old 04-23-2013, 06:37 PM   #12
NewMtang's Avatar
Is that regular or supersize?
Old 04-23-2013, 06:39 PM   #13
Geiger's Avatar
Correct me if im wrong but bad shocks wouldnt make one side lower. You can compress them by hand so they certainly arnt holding the car up... Simply dampening bumps
2008 GT/CS , 17k original miles, bagged with airlift v2, cammed, and some bolt ons.
Geiger is offline   Reply With Quote
Old 04-23-2013, 06:51 PM   #14
Venomouz831's Avatar
Have had the same issue on all my mustang new edge, only fix was coilovers
)02 Gt, Founder of WE2G
Old 04-23-2013, 07:00 PM   #15
1lowGT's Avatar
Just slide an isos out on the side that's higher
05:01 AM
