What color RED - Mustang Evolution
Old 04-23-2013, 02:15 PM   #1
Peterzinyou's Avatar
What color RED
My 04 GT is either TORCH RED, LASER RED, or COLORADO RED? Whats the official color from Ford?
Borla S-Type stingers, BAMA SCT tuner, K & N Typhoon CAI, Classic Design Concepts light bar, MACH 1 chin spoiler, MACH 1000 w JVC Kvw 500 HU, plastidipped hood scoop, wing & Premium GT rims, painted calipers, 3.73 gears, black Bullitt fuel door, MMD hood struts, sub-frame connectors, SVE uca & lca, Power Stop drilled/slotted rotors
Peterzinyou is offline   Reply With Quote
Old 04-23-2013, 02:16 PM   #2
1slosix's Avatar
i believe '04 is torch red
carving corners like a boss
Old 04-23-2013, 02:17 PM   #3
iLLRedGT's Avatar
Torch red
iLLRedGT is offline   Reply With Quote
Old 04-23-2013, 02:18 PM   #4
Now if someone says laser red, ill lose it, thanks
Old 04-23-2013, 02:21 PM   #5
Blogger
99ford's Avatar
And you can confirm this by looking at the drivers door panel there will be a sticker there and it should be top right as you looking down it will probably have a letter proceeded by a number.
On mine it is G2 so it's redfire metallic
Edit: It may not have a number beside it it be two letters like UA for example.
But just google that code and it should come up. You may want to type in Ford then the code, or mustang (then code).
Old 04-23-2013, 02:30 PM   #6
I thought TORCH RED, but of course different sites have different names. Thanks guys
Old 04-23-2013, 06:02 PM   #7
iLLRedGT's Avatar
no prob. Too many non facts on the Internet these days
Old 04-23-2013, 06:31 PM   #8
Geiger's Avatar
Ive seem the code in my door even pull up as colorado red online ... But ive always knows it as torch red. All i know is the guy who airbrushes my rock chips uses d3 paint code and the paint matches.
2008 GT/CS , 17k original miles, bagged with airlift v2, cammed, and some bolt ons.
Geiger is offline   Reply With Quote
Old 04-23-2013, 07:47 PM   #9
Kstangs2002's Avatar
This is the info i got from AMERICAN MUSCLE good info but i didnt see colorado red only 2 reds torch red and laser red
ID:	103971   Click image for larger version
Kstangs2002 is offline   Reply With Quote
Old 04-23-2013, 07:48 PM   #10
I meant red fire red ooops
Old 04-24-2013, 11:34 AM   #11
Rumplemenz's Avatar
Colorado red and torch red are the same... speak from experience as ive painted areas on my TR stang using colorado red and its an identical match... a torch red stang is color code D3/M7042 which is called colorado red by some vendors
04' TR Mach 1 w/ IUP-Vortech V2 3.48" pulley-aftercooler-Anderson PP-90mm MAF-SVT pump-42lb frpp injectors-Steeda battery/trunk-frpp 4.10's-SOS Pillar w/ Ford Racing Fuel,boost/vac gauges-aluminum DS-Steeda tri ax-caster cambers-eibach damper and pro kit-MM FL subframes-borla stinger catback-17x10.5 TT-nitto 555r-04 cobra mirrors/side skirts-CDC decklid panel,billet fuel door-sequential tails-Mach 1 sills-billet antenna-MGW Mach 1 plate covers-MGW brake handle-35% tint-455 rwhp 389 tq
Rumplemenz is offline   Reply With Quote
08:35 AM
