CAI - Mustang Evolution
Old 04-25-2013, 10:33 PM   #1
SilverPonyGT's Avatar
CAI
Alright fellas thinking about getting an airaid CAI I have the cheap one from AM the sr chrome fender well, my questions are 1. Is it worth it to change I have a tuner to maximize gains 2 is plastic better than metal? 3 and is a non fender well like the airaid better?
SilverPonyGT is offline   Reply With Quote
Old 04-26-2013, 06:41 AM   #2
1996mustang's Avatar
Plastic is a bit better due to heat dissipation at least i think it is since k&n used plastic and jlt as well. A fender intake or cai is better since u will suck in cold air rather than hot air coming from a ram air intake like airraid. And yes woth a tune you would maximize your gains with the intake.
---------- Post added at 08:41 AM ---------- Previous post was at 08:38 AM ----------
However the intake you have from sr will perform just as well to be frankly honest. The other debate is that aluminum keeps the cold air cool and may get engine bay temp to warm up the air. It will stick be cold air coming in to the motor regardless.imo i did an easy fix to both problems with metal is heat wrap the outside portion and you will maintain a better constant flow of cold air coming in fron the intake. Overall the sr intake is a good choice for your money its the same setup as a bbk cai minus the price for the bbk name. So you have a well worth intake.
Old 04-26-2013, 07:40 AM   #3
Region: Arkansas
I'm inclined to agree with 96mustang here on plastic vs metal, but the physics argue otherwise.
At the velocity that air is passing through the tube, the ambient temperature is not sufficiently high enough to increase intake charge temperature. If it does, the movement of the air mass will serve to cool it back down anyways.
Think wind, moving air is cooler than stagnant air and you can have a cool breeze on a very hot day.
If the charge temperature does increase, it is likely a minimal increase and should have no ill effects.
I can go find research on this if anyone would like; I'm no professional physicist, but the math checks out.
BackPressure is offline   Reply With Quote
Old 04-26-2013, 07:52 AM   #4
bullitt1075's Avatar
Send a message via Skype™ to bullitt1075
I agree, you can heat wrap your metal intake, or plasti dip it like I did, to insulate it from under hood temps. I would save your $ for another mod.
ID:	104326   Click image for larger version
Proud owner of Bullitt #1075
bullitt1075 is offline   Reply With Quote
Old 04-26-2013, 08:20 AM   #5
theweekday's Avatar
Alright I have a question, so why on AM they get different HP gains with different tuners?
theweekday is offline   Reply With Quote
Old 04-26-2013, 08:43 AM   #6
1lowGT's Avatar
I agree with both..
Old 04-26-2013, 08:47 AM   #7
All cars are different whether they be the same year same make same model the way the engine was built or age of the engine would vary in hp ratings and gains as well as to what else the car has added on bolt on wise
Old 04-26-2013, 10:53 AM   #8
Alright thanks guys for your input! Ill just save my mula maybe buy some gears instead!
Old 04-26-2013, 10:56 AM   #9
Venomouz831's Avatar
Yea stick with the sr intake
)02 Gt, Founder of WE2G
Old 04-26-2013, 11:30 AM   #10
And this is why I am a big advocate of dyno tunes vs mail in tunes.
Old 04-26-2013, 12:36 PM   #11
theweekday's Avatar
What's mail in tunes, like over the Internet?
Old 04-26-2013, 01:59 PM   #12
Yes cause they base the tunes on cars supposedly tuned with the same bolt ons. However too many variables are in play so not every car will get the maximum they could get. But on an average is what the tunes are rated for
Old 04-26-2013, 02:12 PM   #13
That's why they are decent for small bolt on cars, but not for cars with big mods like SC,TC, Cams ect...
Old 04-26-2013, 03:01 PM   #14
theweekday's Avatar
So basically if a shop uses a sct tuner, they can dyno tune the car for different tunes and load them on the tuner itself? Correct me if in wrong
Old 04-26-2013, 04:50 PM   #15
Correct. A shop custom tines the car to your car with all that u have on it.
08:40 AM
