gov - Mustang Evolution
Old 04-26-2013, 12:29 PM   #1
04_sonicblue's Avatar
gov
what would I gain if I was to take off my gov?
-2004 gt
04_sonicblue is offline   Reply With Quote
Old 04-26-2013, 12:54 PM   #2
DaBluedude's Avatar
By gov I assume you mean the speed limiter. In which case you would gain a slightly higher top speed... Which isn't really all that useful.
2003 Mach 1
Old 04-26-2013, 01:16 PM   #3
I believe the gov in the 99-04 GT is actually around 140 which is about where you will give out stock.
Old 04-26-2013, 02:37 PM   #4
well guys I hit 150 in it no problem, and yes that's what I meant if you wanna put it that way, but I was just doing some reading online and what I got out of it is that if you take of the gov "speed limiter" it would help 0-60 a little to
---------- Post added at 02:37 PM ---------- Previous post was at 02:36 PM ----------
and yeah I agree no need for 140+ lol not of any use at all
Old 04-26-2013, 02:39 PM   #5
Venomouz831's Avatar
If its manual would you need to upgrade the driveshaft?
)02 Gt, Founder of WE2G
Old 04-26-2013, 03:14 PM   #6
theweekday's Avatar
Is there a write up on how to remove it?
theweekday is offline   Reply With Quote
Old 04-26-2013, 03:16 PM   #7
Remove the gov speed or driveshaft?
Old 04-26-2013, 03:20 PM   #8
theweekday's Avatar
The gov
Old 04-26-2013, 03:26 PM   #9
I believe a tuner will do that
Old 04-26-2013, 03:28 PM   #10
theweekday's Avatar
I think your right, I didn't even think about that
Old 04-26-2013, 04:24 PM   #11
2002VertGT's Avatar
I have driven a 00gt and my 02gt to speeds higher than 140 without a gov kicking in....just the top end of the car not wanting to go anymore. I know with a tuner it has options to SET a speed and rev limiter, never known one to be set on the car stock.
My neon gov would literally **** the fuel off at 118mph, this never happens in my mustang
4.10 Gear/RPM thread
Old 04-26-2013, 04:49 PM   #12
Slow4V's Avatar
I've taken my old GT to 145 being stupid and a Necio..
I don't understand why you would want to go that fast unless your a Supra, or Have a really fast car Lol.. Just kidding
I say SCT handheld would delete the GOV.
And yes a better driveshaft +1
We are lucky a 2 piece driveshaft wasn't invented 99-04 like in the 2011+ V6 mustangs. I hear those things blow up past 100 Mph
Old 04-26-2013, 05:00 PM   #13
theweekday's Avatar
Lol. So my 00 GT has a single driveshaft?
Old 04-27-2013, 07:30 AM   #14
DaBluedude's Avatar
Removing your limiter will not affect 0-60
2003 Mach 1
Old 04-27-2013, 07:50 AM   #15
1996mustang's Avatar
Speed gov no. Rpm gov yes mostly on automatic
Old 04-27-2013, 08:05 AM   #16
theweekday's Avatar
That's what I'm interested in
Old 04-27-2013, 08:22 AM   #17
appreciate guys thanks
Old 04-27-2013, 10:41 AM   #18
DaBluedude's Avatar
Disagree. The gt flat lines before the rpm cutoff. There's no point revving it higher. Adjusting the shift points on the auto does help. But raising the rpm limiter on a Bolton or stock sn95 car won't do you any good. All you'll do is jeopardize the valve train.
2003 Mach 1
05:28 PM
