Now, on to fog lamp issues (and other quirks with my 2000 GT) - Mustang Evolution
Old 04-26-2013, 07:22 PM   #1
Ok, now that I've figured out cruise control, I'm still working down the list of quirky issues I'm having with this 2000 GT I bought. if anyone can offer some guidance, much appreciated. The following components are currently not working:
Fog Lamps
Cigarette Lighter
Charging port in console
TRAC light (I think*)
Fog Lamps not working- all fuses under dash are integral, including #38 for fog lamps, and my test light comes on when touching each one. The FOG DRL fuse in the engine compartment also lights up the test light.
I then turned the car on, turned parking lights on, pulled the fog bulb out of housing and touched the bulb connector with test light. Nothing. Took fog lamp switch out of the console, pulled apart and when touching all prongs within the switch, test light does nothing. I'm assuming this means no power going to switch and thus nothing going to bulbs. But as I said, all fuses are active. Does this mean there's a break in the line somewhere between fuse and switch?
Cigarette lighter doesn't work- Fuse 1 is integral, test light lights up when touching fuse.
Charging port in console doesn't work - POWER POINT fuse within engine compartment lights my test light up.
TRAC control - Fuse 5 is integral and lights my test light up. I am going to ask a stupid question here (the * from above). When my tires spin at take off, a little "racing wheel" light goes on within the dash. I assume this is traction control kicking in, so maybe it works? The reason I don't know for sure is, when i push the TRAC button no light comes on the dash to tell me it's on, and I've never had traction control on a vehicle before. I took the console cover off and disconnected both the TRAC switch and lighter. I then hit each one with my test light, the key on, and neither the Trac switch nor the cigarette lighter come on.
A little confused.
Thanks in advance for your help!
Phoo
awwphooey is offline   Reply With Quote
Old 04-26-2013, 07:31 PM   #2
1996mustang's Avatar
Fog Lamps
Cigarette Lighter
A little confused.
Phoo
Check the relay for the fog lights. Also check the actual back of the cig lighter and power port to see if they get power. Could be as simple as the plugs and plugged in as for trac i know nothing on that one yet since i dont believe in traction control lol. Ill take a looksie on it as well when i get home and on a comp to get on alldata
Old 04-29-2013, 08:56 AM   #3
Thanks for the reply-
Thanks for taking the time everyone-
To clarify on testing fuses, all were integral visually and each side of every one under dash lights test light when applying to both sides of fuse. I also checked all relays and fuses under hood, same results.
Where I'm at right now- with the parking lamps ON, the LEDs in the fog light switch and TRAC switch DO NOT come on with the rest of the instrument panel illumination. I replaced the FOG switch just in case, and while doing found there is no power going to any of the wires leading to the switch. As for TRAC control, apparently it works as the little spinning wheel comes on from the dash when I spin the tires (intentionally to check if it came on), but in checking the connector to both the TRAC button and the cigarette lighter, neither have power coming to them. I haven't checked back of power point yet, but going to assume the same.
I'll keep ya'll posted.
03:58 AM
