who on here has done the pi swap?? - Mustang Evolution
Old 04-28-2013, 10:11 AM   #1
98GTCONV's Avatar
Need help!!
98GTCONV is offline   Reply With Quote
Old 04-28-2013, 05:02 PM   #2
98GTCONV's Avatar
Need help with the cam sprocket bolt and washer! Who has experience and even knows what im talking about??????
Old 04-28-2013, 06:01 PM   #3
1996mustang's Avatar
Im assuming your cam gears are not pressed on right?
Old 04-28-2013, 06:03 PM   #4
98GTCONV's Avatar
No the npi cam sprocket bolts were different than the pi's. So I can't reuse it
Old 04-28-2013, 06:41 PM   #5
The pi heads u acquire didnt have the cams qith them?
Old 04-28-2013, 08:19 PM   #6
98GTCONV's Avatar
It included, heads, cams, valves, lifters, and rockers. Didn't come with valve springs or cam gears. So I bought new valve springs and am reusing my old cam gears. But the cam sprocket bolts are different. And I can't find the one that I need for the pi heads.
Old 04-28-2013, 09:31 PM   #7
You got a pic of what you got for the cam gears? If it came with cams it should have had the cam gears. Best bet is to get the either romeo or Windsor ill research it ib a few im sure it's Windsor bit ill recheck on which sprocket to have
08:14 AM
