Rev limiter - Mustang Evolution
Old 04-28-2013, 05:20 PM   #1
Nitrous02gt's Avatar
Rev limiter
I saw a post on the new mustangs about this so I figured I ask about my I have a 02 gt and I was wondering 1. What's the stock rev limiter at and 2. What's the highest I can make it for best performance and still safe for my motor. I have stock mani and 3.73 gears.
Nitrous02gt is offline   Reply With Quote
Old 04-28-2013, 07:42 PM   #2
Anybody?? :/
Old 04-28-2013, 10:34 PM   #3
cliffyk's Avatar
1. 6050 RPM
2. 6050 RPM -- cheap, safe, fast; you can only pick two...
There is no benefit to bumping the rev-limiter on a stock 2V, even the PI models. The heads are not breathing well by then, and the stock 65 mm TB and upper plenum (the plenum is the weak point) are all done by 5500 rpm...
If you want to begin to build up performance without breaking the bank (or the engine) read this thread...
Old 04-28-2013, 11:22 PM   #4
Originally Posted by cliffyk View Post
1. 6050 RPM
I have a 78 mm tb and plenum combo with shortys o/r x pipe flow masters and hyper tech tune idk I thought a higher rev limit would help cuz it's an option on my tuner
Old 04-28-2013, 11:31 PM   #5
Does it matter with my mods? Idk I'm bad at this stuff lol
Old 04-28-2013, 11:50 PM   #6
cliffyk's Avatar
Nope, in fact "safe" and raising the rev-limiter on the 2V with the stock bottom end (the rods are the weak point) do not belong in the same sentence...
Old 04-28-2013, 11:52 PM   #7
Should I lower it?? Lol I have a 100 shot of nitrous and now your scaring me.
Old 04-29-2013, 12:57 AM   #8
cliffyk's Avatar
No, though I find it surprising that you would be concerned about it being "safe" to raise it--and yet be running a 100 shot of nitrous oxide, which is technically not "safe" on an engine designed to produce 260 HP at the flywheel; a "+100 shot" makes that 360 fwHP.
Now consider that when Ford's engineers designed the '03/'04 Cobra to produce 390 fwHP they decided the GT bottom end would not be "safe", and used forged components.
So can you better define your definition of "safe"?
If by "safe" you mean "this is my DD and I cannot afford to blow up the motor", then stick with an n/a bolt-on build and no power adders.
OTH if to you "safe" means "I want to have a GT that stands out in the crowd and can afford to someday rebuild/replace the motor" then keep it under 400 fwHP and you'll be OK. This will shorten the engine's useful life, however most likely not catastrophically.
For "balls and all" bring it up to 425 rwHP, run it hard 4 or 5 times, and enjoy the show when it throws a rod...
KB New-edge blows on dyno
Old 04-29-2013, 07:10 PM   #9
slow281
sixpac's Avatar
Region: Nebraska
Every now and then when I do a good burnout.. (Showing off ik bad right) I hit the rev limiter.. If I lower the rev limiter would that be a safe measure to take? I never run the strip Kristin don't have money to rebuild another motor..
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 04-29-2013, 07:34 PM   #10
cliffyk's Avatar
No need to--Ford set it at 6050 RPM because it was a safe limit...
Old 04-29-2013, 08:13 PM   #11
BigB227's Avatar
I'd cry if that happened to my car no lie, but then again I wouldn't boost on stock internals
BigB227 is offline   Reply With Quote
Old 04-29-2013, 10:50 PM   #12
Tomb1987's Avatar
U can boost stock internals. Mine was boosted 3 years 400 hp and just let loose 2 weeks ago (meth kit failed ran lean). With a good tune and stay around 380-420 hp should be safe for awhile but depends on tune.
2002 mustang gt
Future beast
Tomb1987 is offline   Reply With Quote
Old 04-29-2013, 11:51 PM   #13
BigB227's Avatar
I know that it can be done and that people have done it but I'd rather be safe than sorry but that's just me lol I'd pay the money to have the forged internals
Old 04-30-2013, 06:35 AM   #14
Tomb1987's Avatar
I dunno man I love boost to much to have waited to buy forged first lol
2002 mustang gt
Future beast
Old 04-30-2013, 07:49 AM   #15
How much it cost to get forged internals? Anyone have a ball park number?
Old 04-30-2013, 08:51 AM   #16
BigB227's Avatar
I saw eagle forged internals for street and strip for $1700ish and competition for almost $2000
Old 04-30-2013, 09:44 AM   #17
DaBluedude's Avatar
Add another grand minimum to get someone to build it for you.
2003 Mach 1
Old 04-30-2013, 09:45 AM   #18
Ouch
Old 04-30-2013, 11:01 AM   #19
Can anyone provide a good link of some good internals to use if I'm looking for 450-550 hp?? I have been looking but have no idea what I'm looking at lol
Old 04-30-2013, 11:08 AM   #20
Technique251's Avatar
I saw on MMR that they install forged pistons n rods for 1500.
Technique251 is offline   Reply With Quote
Old 04-30-2013, 11:14 AM   #21
rev limiter is not where the highest power is made, itsjust he highest it can go wtihout messing stuff up, no need to modify it
Old 04-30-2013, 12:17 PM   #22
Matticus's Avatar
+1
Matticus is offline   Reply With Quote
Old 04-30-2013, 03:16 PM   #23
Tomb1987's Avatar
U can run boost up to about 400 rwhp if u have a good tune on ur stock bottom end
2002 mustang gt
Future beast
Old 04-30-2013, 03:28 PM   #24
How do I get a good tune? I have a hyper tech one right now
Old 04-30-2013, 03:53 PM   #25
slow281
sixpac's Avatar
Region: Nebraska
Are you N/A?
2001 GT - True Blue
Old 04-30-2013, 04:14 PM   #26
I have a 100 shot of nitrous I use for the track
Old 04-30-2013, 05:24 PM   #27
slow281
sixpac's Avatar
Region: Nebraska
Idk if you have to tune for nitrous but best handheld is sct from American muscle
2001 GT - True Blue
Old 04-30-2013, 05:44 PM   #28
Lol sucks so expensive since I already have one but no it doesn't have a nitrous option
Old 04-30-2013, 05:51 PM   #29
slow281
sixpac's Avatar
Region: Nebraska
Idk I the sct one does
2001 GT - True Blue
Old 04-30-2013, 05:53 PM   #30
Oh I was saying my hyper tech doesn't have anything for nitrous
Old 04-30-2013, 05:54 PM   #31
slow281
sixpac's Avatar
Region: Nebraska
You could ask the guys at AM
2001 GT - True Blue
Old 04-30-2013, 10:41 PM   #32
DaBluedude's Avatar
Then you aren't using nitrous then? You need a custom dyno tune to run nitrous properly.
2003 Mach 1
Old 04-30-2013, 10:51 PM   #33
Tomb1987's Avatar
Best place to get a tune is going to be a reputable tuner in ur area hell put it on the Dino and see exactly what the car is doing and make adjustments. Mail order tunes are just a bandaide
2002 mustang gt
Future beast
04:21 PM
