CEL and 2 codes, need help - Mustang Evolution
Old 04-28-2013, 05:34 PM   #1
Kevo91's Avatar
Region: Utah
Hey guys, I just bought a 98 GT. Anyway it threw a CEL and codes p1151 (running lean) and p1152 (rich), also on the OBD scanner o2 sensor and o2 heater won't clear, and occasionally I get a little white smoke out of the driver side tailpipe. I'm figuring oxygen sensor, what do you guys think?
Kevo91 is offline   Reply With Quote
Old 04-28-2013, 05:59 PM   #2
1996mustang's Avatar
A little white smoke when u initially start up or any time? If anything you may wanna check your coolant levels just in case it isnt condensation. Also look for a exhaust leak coming from the o2 upstream since its the upstream o2 is the ones that read what the motor does
Old 04-28-2013, 06:12 PM   #3
Kevo91's Avatar
Region: Utah
Not on startup so it's not a valve seal, it's only when I really get on the gas and get the RPM's up high. I cleaned the MAF and there are no vacuum leaks
---------- Post added at 05:12 PM ---------- Previous post was at 05:11 PM ----------
Coolant levels are good too
Old 04-28-2013, 06:23 PM   #4
Could be a possible sensor however just to be safe run a thorough check on anything to rule it out. But probably is the sensor since it reads lean and rich from the same bank
Old 04-28-2013, 06:33 PM   #5
Kevo91's Avatar
Region: Utah
Thanks I'll check it out, it did sound like there was a minor exhaust leak up around my passenger side cat. Dumb question but could a faulty sensor on the passenger side cause the smoke on the driver side? My last stang was a 90 GT so it didn't have all the computer bs
Old 04-28-2013, 06:40 PM   #6
Do you have an x or h pipe? Either or both cross over the ehaust from both side to equalize flow so it is quite possible to occur
Old 04-28-2013, 06:49 PM   #7
Kevo91's Avatar
Region: Utah
Nope it's stock
Old 04-28-2013, 07:50 PM   #8
So h pipe stock then so it is possible
Old 04-28-2013, 07:59 PM   #9
Kevo91's Avatar
Region: Utah
Ok so it sounds like it's just a matter of an p2p sensor, I'll just have to figure out which one. Awesome thanks for the help
Old 04-28-2013, 09:10 PM   #10
Kevo91's Avatar
Region: Utah
O2...stupid auto correct lol
Old 04-29-2013, 10:18 AM   #11
Kevo91's Avatar
Region: Utah
UPDATE: alright so I was driving on the freeway today and the stang was real sluggish, had to floor it in 4th gear to maintain 70 mph. Definitely a bad oxygen sensor? (used alot more gas than usual too)
Old 04-29-2013, 01:21 PM   #12
cliffyk's Avatar
If you literally had to "floor it in 4th" to maintain 70 MPH then the problem is something much more serious than an O² sensor...
Old 04-29-2013, 01:39 PM   #13
Kevo91's Avatar
Region: Utah
Sorry I meant 5th gear. In 4th I could only pick up speed slowly and it was idling rough too. On the freeway it was kind of on and off, it would drive fine for a min then get sluggish again
11:39 PM
