Oil Capacity - Mustang Evolution
Old 04-28-2013, 06:30 PM   #1
buickregal79's Avatar
Oil Capacity
So i have a 01 Gt with the 4.6 2v. Last oil change i did the car took 6 quarts to read full on dipstick. Now i know ts been a common question on here with many answers whats the true amount needed? I tried 5 quarts like the owners manual said but it said a quart low. Thanks in advance!
Shutting off the thought process is not rejuvenating; the mind is like a car battery - it recharges by running.
buickregal79 is offline   Reply With Quote
Old 04-28-2013, 06:43 PM   #2
v8pony's Avatar
6 qts.
2002 5spd GT
Feb 2013 Mustang of the Month
Old 04-28-2013, 06:49 PM   #3
Thank you, i don't get why the manual and even the ford tech book says 5? like wtf
Old 04-28-2013, 10:41 PM   #4
cliffyk's Avatar
The original recommended fill for the 4.6L was 5.0 qt; however independent testing in late 2000 revealed some oil starvation during high-G (VERY high-G) cornering and Ford increased the recommend capacity to 6.0 qt in 2002 (you can download the owner's manuals here to see this change).
The recommended fill and the dipstick markings were the only changes--you '01 may be late MY production or perhaps someone changed the dipstick...
Old 04-28-2013, 10:57 PM   #5
MidnightBlueGT's Avatar
Thats weird. I gotta 02 and changed mine last month and 5 filled it all the way.
Old 04-28-2013, 11:32 PM   #6
cliffyk's Avatar
It's the dipstick markings. This was not a change made by throwing a switch overnight, but was phased in during production. I have seen early to even mid-2002 MY engines with the old dipstick; it depends on when the engine was assembled--not the car.
6.0 qt is the recommended fill for all 4.6L Mustangs--there's a TSB out there but I cannot find it just now...
Old 04-29-2013, 07:29 AM   #7
v8pony's Avatar
Always put 6 qts..if your dipstick reads full at 5qts, get yourself the new updated dip stick, grabbed mine from ford for 20 bucks or something..my car was built in January of 02 and I had to grab the new dipstick to get a correct reading
2002 5spd GT
Old 04-29-2013, 07:35 AM   #8
cliffyk's Avatar
Or just get a 3-corner file, drill a hole, or get Jaws (from Janes Bond, not the shark) to bite it for you and make a new mark.
One could even perhaps remember how much above the old mark represents "full"...
Old 04-30-2013, 06:58 PM   #9
Sweet thank you guys and good job on fords part on catching the issue!
Old 04-30-2013, 07:34 PM   #10
cliffyk's Avatar
it was independent testing, not Ford, that identified the issue--however Ford did do us service by acknowledging it and changing their recommendation and the dipstick...
03:17 AM
