White Face Gauges - Mustang Evolution
Old 04-29-2013, 06:22 PM   #1
MineralGrayGT's Avatar
Region: Wyoming
White Face Gauges
Bought some white face gauges from AM and have now worries with installation except the fact that wiring isnt my best area haha so can anyone simplify the wiring and how they did it for me itd be greatly appreciated.
MineralGrayGT is offline   Reply With Quote
Old 04-29-2013, 06:36 PM   #2
ksrumbel's Avatar
Did you get the overlays or the simco cluster that they sell?
ksrumbel is offline   Reply With Quote
Old 04-29-2013, 06:40 PM   #3
Region: Wyoming
Overlays
Old 04-29-2013, 06:52 PM   #4
ksrumbel's Avatar
Overlays
They have a pretty good installation guide on the AM website. Check it out. Just download the PDF file.
http://www.americanmuscle.com/mustan...es-how-to.html
Old 04-29-2013, 06:53 PM   #5
MidnightBlueGT's Avatar
^ yup, am has good install guides
Old 04-29-2013, 08:44 PM   #6
Region: Wyoming
I just dont understand connecting the red wire to the large gray wire. Does the gray wire come out or....?
Old 04-29-2013, 11:09 PM   #7
1996mustang's Avatar
What i did was just splice it in with the splice connectors to wires goin from the cluster. Found a ground and constant power wire and that was that.
Old 04-29-2013, 11:10 PM   #8
I have the reverse glow
Old 04-29-2013, 11:23 PM   #9
slow281
sixpac's Avatar
Region: Nebraska
I want those.. Wares u get them and we're they hard to install ?
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 04-30-2013, 06:03 AM   #10
Quite easy to install i got them from am.
Old 04-30-2013, 06:04 AM   #11
96smoke's Avatar
You'll love them, got em on my 96
96smoke is offline   Reply With Quote
Old 04-30-2013, 09:17 AM   #12
Foxone's Avatar
Wiring part is easy, getting them to lay flat is the hard part, you will have to glue them down some to keep the needles from rubbing.
Foxone is offline   Reply With Quote
Old 04-30-2013, 09:59 AM   #13
FYI after its all done consider leaving off the clear cover panel for a bit to ensure needles move freely, sometimes they stick on the overlay and need to be pulled out TINY bit to compensate for the ticker material, you cant and should not do this by hand use the tools provided for this job to pull em out a bit (two pieces of metal on each side to even the load of pulling so the tiny little metal rod isnt bent that the needle sits on)
Old 05-02-2013, 09:56 PM   #14
Region: Wyoming
Got em all done and in and they look great
Old 05-03-2013, 06:07 AM   #15
Zamora03's Avatar
I love mine
Zamora03 is offline   Reply With Quote
06:24 AM
