Suspension question - Mustang Evolution
Old 04-29-2013, 08:06 PM   #1
BigB227's Avatar
Suspension question
I really want to upgrade my suspension next but if I get this handling package what else would I need???
http://www.americanmuscle.com/eibach...rt-9404gt.html
Will I need cater/camber plates with this package?? Do I need a bump steer kit???
Because all of that gets pretty expensive lol but I don't want to completely lower my car to the ground, I need to get in and out of my driveway so I don't want anything that dramatically lowers it but I want to upgrade my crappy stock suspension.
BigB227 is offline   Reply With Quote
Old 04-29-2013, 08:11 PM   #2
fastmustangs1's Avatar
Do you have subframe connectors welded in yet? That suspension package is ok I dont know the spring rates off hand with those springs. CC Plates wont be a bad idea for alignment purposes. Bumpsteer kit should b determined after you get get your suspension installed you can park your car on a flat surface and check you outer tiered angles relative to your front arms. The tierods should be parrelal to the control arms so if it is off then you will get bump steer issues.
fastmustangs1 is offline   Reply With Quote
Old 04-29-2013, 08:15 PM   #3
BigB227's Avatar
No I only have the stock subframes that came with the convertibles so that's on my list and I was thinking that I'd have to get the caster/camber plates so thanks for reassuring me and yeah so if it aligns good I don't need the bump steer but if it doesn't then ill have to get it right?
Old 04-29-2013, 08:24 PM   #4
CC plates would be a great idea in fact because it would allow you to run an additional 1-2 degrees of positive castor on your setup so you dont have to run huge amounts of neg camber, which will kill tire life in the long run.
Old 04-29-2013, 08:35 PM   #5
BigB227's Avatar
Oh ok cool thank you very much and do you think this is a good set up??
http://www.americanmuscle.com/sr-cas...-kit-9404.html
Old 04-29-2013, 08:37 PM   #6
Im not to familiar with SR springs though. Not sure what the spring rates on those as well. What are your goals for your car down the road.
Old 04-29-2013, 08:41 PM   #7
BigB227's Avatar
For now I'm going to be staying N/A but in a couple years I plan to run a supercharger, been looking at Vortech v3 SI
Old 04-29-2013, 08:43 PM   #8
I would recommend going to H&R Super Sport Springs. You will need a good set of struts and shocks with those springs.
Im running Koni Single Adjustable shocks on my car!
Old 04-29-2013, 08:48 PM   #9
BigB227's Avatar
What would be good struts that you would recommend?? And I have KYB Gas a just rear shocks on now? They any good to keep??
Old 04-29-2013, 08:50 PM   #10
KYBs not so good with higher spring rate H&Rs. I would recommend saving for either Bilstein or Koni shocks. They are great quality and offer a warranty as well.
Old 04-29-2013, 08:52 PM   #11
BigB227's Avatar
Ok thank you for the advice, would it be unwise to drive with KYBs if I got these springs until I saved up for them or should I install them at the same time??
Old 04-29-2013, 08:54 PM   #12
joedelpen's Avatar
Region: Nevada
Camber castor plates and maybe rear upper and lower control arm. It will put those rear wheels to the ground. I'm looking to purchase the same kit with what I've suggested, also including a strut tower brace and a few other thing for my 05 convertible.
POLICE PROTECT AND SERVE THIER WALLETS
joedelpen is offline   Reply With Quote
Old 04-29-2013, 08:56 PM   #13
BigB227's Avatar
Yeah I eventually want to upgrade me rear UCA and LCA
Old 04-29-2013, 08:58 PM   #14
I wouldn't change to aftermarket Upper control Arms. They will increase to much bind in handling. Just replace OEM rubber bushings if need be. Urethane UCA bushings will put to much stress on the torque boxes.
Old 04-29-2013, 09:00 PM   #15
BigB227's Avatar
Oh really??? I did not know that thanks
Old 04-29-2013, 09:02 PM   #16
No problem good luck. Got anymore questions you can pm me.
Old 04-29-2013, 09:04 PM   #17
joedelpen's Avatar
Region: Nevada
That's good info. I'll keep that in mind. Thank
Old 04-29-2013, 09:05 PM   #18
BigB227's Avatar
Thank you very much and I will if I have anymore questions
Old 04-29-2013, 09:05 PM   #19
That is for mustangs with a 4 link setup pre-2005 cars.
Old 04-29-2013, 09:06 PM   #20
joedelpen's Avatar
Region: Nevada
---------- Post added at 08:06 PM ---------- Previous post was at 08:06 PM ----------
Oh ok. Cool
Old 04-29-2013, 09:07 PM   #21
2005 is the first year Ford went to a 3 link set up with a panhard bar standard.
Old 04-29-2013, 09:22 PM   #22
joedelpen's Avatar
Region: Nevada
I just bought mine in amazing condition with only 60,000 on it. So I'm just learning the mustang family. I usually always drove Riggs lifted for dessert fun. But continuos broken part from being ballsy is more expensive then building a car for speed and show eventually. Anyways thank for the info ill put it to good use.
Old 04-29-2013, 09:54 PM   #23
Im gonna revalve my konis for H&R race springs go to smaller diameter front sway bar and install my panhard bar.
Old 04-29-2013, 10:02 PM   #24
joedelpen's Avatar
Region: Nevada
Nice. So you know a lot about mustangs? Or cars basically in general. I work on my own car all the time as long as the funds can keep me doing what a love. I'm actually working on getting in to a custom shop of some sort. I'll soon have the mustang I see in my head though no doubt.
Old 04-29-2013, 10:04 PM   #25
I was a pro rc driver and spent years with suspension engineerings and lots of stuff
transfers over to autos.
Old 04-29-2013, 10:11 PM   #26
joedelpen's Avatar
Region: Nevada
Sweet! What I would do to have a chance to learn the more in depth mechanics. Las Vegas is hard to do anything cause so many people are out for themselves. You know. I guess I keep taking thinks apart and putting them together right and take knowledge here and there from guys like yourself I'll be ok... Thanks for sharing info "fastmustang1" always appreciate a little bit more stuff to cram in my brain.
Old 04-29-2013, 10:15 PM   #27
no problem lol.
Old 04-30-2013, 09:08 AM   #28
AmericanMuscle.com
Sponsor
AMDanBailer's Avatar
Eibach Mustang Pro-System-Plus (94-04 V8 Convertible) 3530.680 - Free Shipping!
All of this information being tossed around in here is great! You could run any of the different variations of Springs/Strut Combo's that you guys talked about. You could also run the Eibach Pro-System that you linked to! That kit is great and is definitely one of our most popular suspension kits.
Since the Pro-Kit will only lower you about 1.3" in the front and 1.4" in the rear, you actually won't need Caster Camber plates just yet. Anything more than 1.5" in the front will throw off your Camber enough to require them! Just an Alignment will do for anything less than 1.5 ".
I hope this helps! Please let me know if you have any questions or need some assistance in the near future. Our Mustang Experts are here Monday-Friday from 9AM-9PM EST and Saturdays from 9AM-5:30PM EST. If you want to hit them up, their number is 866.727.1266. I can also have one of them call you directly.
-Dan
Old 04-30-2013, 09:16 AM   #29
BigB227's Avatar
-Dan
Great info thank you very much Dan!!! An I have been considering the eibach pro system so I don't get lowered too much
Old 04-30-2013, 09:32 AM   #30
DaBluedude's Avatar
I've installed 2 eibach pro kit plus systems. The anti roll bars make a huggggeeeee difference. Doing the shocks struts springs all with a system designed to work together is a big plus. If you are going to keep running isolaters (and I suggest you do!) then you will probably get away without needing a set of cc plates or a Bumpsteer kit. Personally I got both. You can really dial in the suspension setup with them. My overall drop was only a little over an inch. Which I like. I used the stock isolaters off the stock springs because poly isolaters squeak like crazy. I had to make new lower front isolaters which I used 3/4" inner diameter rubber heater hose for. 6$ and it's quiet and a perfect fit. The pro plus kit really wakes the car up in the corners. I still suggest the cc and Bumpsteer kit but I understand money is big. I had huge Bumpsteer with my wider front tires and hated driving the car without them. As for rear end other stuff. The rear upper and lower control arms are a big liability. I switched to a full tubular design set and it really helps plant the power. A definite buy imo and they are pretty cheap. As a tip though, have a shop do these. Getting my lower axle bolts out was a huge pain in the ***. Had to use an impact hammer and it took forever. No way I would have gotten it out in my garage. Oh and finally, subframe connectors. Couldn't recommend them more. They're cheap, give you a good jacking point and stiffen your ride up. Have them welded in.
2003 Mach 1
Old 04-30-2013, 09:57 AM   #31
you really wont need a bumpsteer kit overall (ive never needed one and I am droped 2 inches or more). If you notice the road driving you around consider it but you wont need it up front
Get GOOD caster/camber plates, most dont allow enough adjustment. Maximum Motorsport 4 bolt have a great warranty and allow a huge adjustment range (and have a spherical bushing to allow better strut shaft movement)
Other than shocks/springs (shocks/struts need to be valved to the spring rate for best results, if your keep a near stock rate you can run your OEM shocks/struts just research this and determine your goal you can always upgrade later if your OEM stuff is in good shape but it makes the ride better if they are working right vs worn out!)
you can look into Endlinks (for the sway bar since it will be up higher due to the taller factory ones going upwards as you lower the car, they are cheap also)
Drive a bit like 200 miles to let settle then get it aligned and get a print out of the specs to see if they actually got you in tolerance or just got you "good enough" and charged you the full price for nothing....
Old 04-30-2013, 01:49 PM   #32
some great info to consider.
Old 04-30-2013, 03:46 PM   #33
Rejekt's Avatar
I went with H&R Super Sport springs, Maximum Motorsports caster camber kit, and Tokico shocks / struts and have been extremely happy with them. The car is beautiful in turns and the stance is perfect with my 18's.
However, the SS springs do lower it a good amount and you have to be careful going over bumps and into / out of dips.
Rejekt is offline   Reply With Quote
« Tranny leak? | Ma »
02:40 PM
