02 GT Bogging Down - Mustang Evolution
Old 04-30-2013, 11:36 AM   #1
Ckennedy121's Avatar
02 GT Bogging Down
I just finished installing my MGW SS and I went to test drive it around the block, keep in mind it started raining really hard, I was working under a car port but I just wanted to test it around the block. The car started making a small wining sound and bogging down to 500 rpms, I had to stop, put it into first and get it moving again. I made it back home but its raining really hard not sure what caused this. Could it have anything to do with the rain or the MGW SS?
---------- Post added at 11:36 AM ---------- Previous post was at 11:35 AM ----------
I thought maybe something got wet it wouldnt cut out but I cant imagine how a shifter would cause air/fuel issues for the engine to not idle/run correctly.
Ckennedy121 is offline   Reply With Quote
Old 04-30-2013, 11:40 AM   #2
Region: Arkansas
I can guarantee its not the shifter unless you installed it all kind of wrong.
I would say maybe you sucked up some water if you went through a puddle or something or like you said got water on a COP or other electrical component.
BackPressure is offline   Reply With Quote
Old 04-30-2013, 11:49 AM   #3
I need to be in court in about an hour. This sucks big balls. I dont trust my car to drive 20 miles in this weather. Damn it.
---------- Post added at 11:49 AM ---------- Previous post was at 11:45 AM ----------
My mom is gonna lend me her truck thank god she loves me.
Old 04-30-2013, 12:05 PM   #4
Should I just let it sit and dry out? I mean not much I can do with the rain right now, but when its not raining what should my next course of action be?
Old 04-30-2013, 02:22 PM   #5
Region: Arkansas
I honestly don't know the course of action, hopefully someone else helps.
Old 04-30-2013, 03:02 PM   #6
Bump. Should I give it a few hours to dry? it's not raining outside anymore
Old 04-30-2013, 03:04 PM   #7
slow281
sixpac's Avatar
Region: Nebraska
Yeah undo the battery too.. Give it a time to reset..
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 04-30-2013, 03:26 PM   #8
Could it be water in my fuel tank?
Old 04-30-2013, 03:39 PM   #9
Count Dragula's Avatar
If water is in your fuel tank I'm sure your check engine light would be on for the evap system. If you have a leak in the gas tank that would alter the pressure it has and your car would basically run like crap.
---------- Post added at 05:39 PM ---------- Previous post was at 05:37 PM ----------
I doubt that is what it is. Just unplug the negative end of the battery and let it reset. If it still messes up could be a plug or coil pack.
2007 Mustang Gt
2.3L Whipple Supercharger
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 04-30-2013, 03:56 PM   #10
Rejekt's Avatar
Yeah, let it reset.
Also, could be a dirty IAC. Mine began to bog down one day in a parking lot, then the CEL turned on, I cleaned my IAC and no probs since.
Rejekt is offline   Reply With Quote
Old 04-30-2013, 04:17 PM   #11
Okay so I reset battery and then I started her up. She's running fine and now I'm going to try and get used to this MGW shifter. It is sick.
Super precise and crisp. I'm afraid I might miss 5th tho
---------- Post added at 04:16 PM ---------- Previous post was at 04:16 PM ----------
And most importantly thanks everyone
---------- Post added at 04:17 PM ---------- Previous post was at 04:16 PM ----------
Also I'm guessing it was the rain because I hit a puddle I tried to avoid but the huge truck took up the entire center of the two lane road and I tried to slow down but I didn't have enough time my front left inner splash guard broke from the car I zip tied it back in place
Old 04-30-2013, 04:28 PM   #12
Miami weather. Flood warning two hours ago now this.
Old 04-30-2013, 04:52 PM   #13
Region: Arkansas
I'm betting that puddle screwed you up. That's a gorgeous photo by the way.
As for missing 5th with the MGW, you won't. You really can take your time going into 5th anyways since its an overdrive gear and your rpms need to drop quite a lot. I usually take a full second or more to go to 5th from 4th when I need to use it.
Old 05-01-2013, 07:45 PM   #14
Thanks man. I'm not worried about 5th like you said by that time I'm just gliding effortlessly into t anyway.
Old 05-01-2013, 08:04 PM   #15
Yeah 5th really isn't too bad. I love mine and when I drive other cars all I can think is their shifters are crap
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 05-01-2013, 08:59 PM   #16
Region: Arkansas
I couldn't agree more. Dad's 07 has a Hurst and I HATE that damn shifter. It's like trying to push the shift handle through concrete, I have to actually engage my traps and delts to move that thing.
Old 05-01-2013, 09:45 PM   #17
I went with MGW I've tested out pro 5.0, steeds tri ax and hurst and I never tested a MGW but I did a lot of reading and YouTube watching before forking out the cash.
Worth every penny!
Old 05-01-2013, 11:48 PM   #18
I got an MGW and never looked back, it's worth every penny.
Old 05-03-2013, 07:58 AM   #19
jjsg09's Avatar
F@#! 5th Gear!
Nice shifter by the way!!!
Old 05-03-2013, 08:35 AM   #20
Originally Posted by jjsg09 View Post
F@#! 5th Gear!
Thanks ! I love it
11:44 PM
