Tune Up Time - Mustang Evolution
Old 04-30-2013, 12:34 PM   #1
theweekday's Avatar
Tune Up Time
So Friday I'm doing a tune up seeing how its been burning gas and the car was sitting for a year before I bought it.
Oil Change
Air filter
Sparkplugs
Transmission filter/fluid
Is there anything I'm missing?
theweekday is offline   Reply With Quote
Old 04-30-2013, 01:23 PM   #2
coolant maybe
Old 04-30-2013, 09:51 PM   #3
1996mustang's Avatar
Coolant exchange, plugs, wires, pcv valve, oil change, fuel filter, air filter ( either clean it or new one ), i wouldnt necessarily do a tranny flush but it is optional, throttle body cleaning, seafoam and i think thats it for my opinion on a tune up.
Old 05-01-2013, 07:37 AM   #4
theweekday's Avatar
What are some good spark plugs?
Old 05-01-2013, 08:15 AM   #5
Mustang936's Avatar
You can never go wrong with Motorcraft
Mustang936 is offline   Reply With Quote
Old 05-01-2013, 09:05 AM   #6
theweekday's Avatar
Yep Ima just go with motorcraft, but what kind tho? I see platinum and copper
Old 05-01-2013, 09:10 AM   #7
v8pony's Avatar
Anyone ever come across a how-to or tutorial on changing plugs in the 2v 4.6?
2002 5spd GT
Feb 2013 Mustang of the Month
Old 05-01-2013, 09:47 AM   #8
theweekday's Avatar
I've been searching and everyone does it different. I don't wanna take off the fuel rail
Old 05-01-2013, 10:25 AM   #9
Autolite coppers are perfect.
Just unbolt the coils one at a time and swap plugs. No need to remove fuel rail, just the intake tubing
Old 05-01-2013, 10:26 AM   #10
Sbales88's Avatar
Exactly what i did
Sbales88 is offline   Reply With Quote
Old 05-01-2013, 10:37 AM   #11
DaBluedude's Avatar
Lots of people forget about brake fluid too. Not a bad idea to swap it out if it's been awhile.
2003 Mach 1
Old 05-01-2013, 11:50 AM   #12
theweekday's Avatar
Old brake fluid can be bad???? =|
Old 05-01-2013, 11:52 AM   #13
Brake fluid absorbs water over the time. Yeah it can go bad so he's right recommendations on a brake fluid flush would be suggested
Old 05-01-2013, 12:55 PM   #14
theweekday's Avatar
Yeah man this car haven't had a tune up since it was bought
Old 05-02-2013, 12:57 AM   #15
DaBluedude's Avatar
It's a bit more money but I suggest a dot 4 brake fluid. Makes a big difference. Dot 4 paired with new stainless steel lines are a night and day difference.
2003 Mach 1
Old 05-02-2013, 05:03 AM   #16
Slow4V's Avatar
Spark plugs , clean injectors , clean out throttle body, change coolant and thermostat , fuel filter .
You can change brake and power steering, but i never do, all runs the same to me. Just saying
Old 05-03-2013, 07:50 AM   #17
jjsg09's Avatar
If you do spark plugs you MUST do them right! Failure to do them correctly will result in them blowing out of the head. Its best to just use the stock Motorcraft plugs. The PI heads below 04 only came with 3 to 4 spark plug threads and have a horrible reputation of blowing out after installing new ones incorrectly.
Old 05-03-2013, 07:54 AM   #18
theweekday's Avatar
Well I changed the fuel filter and b12 it full tank of gas. I reset my trip to 0 and now see that it's getting 21 mpg. I'm going with stock motorcrafts.
It's cheaper bought online vs at advance etc
Old 05-03-2013, 07:56 AM   #19
Slow4V's Avatar
Make sure they are pre gapped if not get specs and gap them !
Old 05-03-2013, 08:00 AM   #20
theweekday's Avatar
I got a gapper just in case!
05:47 PM
