getting a P0430 dtc code - Mustang Evolution
Old 04-30-2013, 05:10 PM   #1
darkshadowGT04's Avatar
My check engine light is on got a P0430 code my stang is all stock other then I deleted my mufflers.. please help thanks
darkshadowGT04 is offline   Reply With Quote
Old 04-30-2013, 09:47 PM   #2
1996mustang's Avatar
Its a code for the cats did you delete them?
Old 05-06-2013, 12:19 AM   #3
code table here: Diagnostic Trouble Code (DTC) Table Free Download
hellozaizai is offline   Reply With Quote
Old 05-06-2013, 02:03 AM   #4
cliffyk's Avatar
Here is what the shop manual says about P0430. If, as was suggested above, you removed the catalytic converters then there is the problem.
You will need MIL Eliminators (you can make them for less than $10), or to turn off the cat monitor in the tune.
07:10 AM
