Odd idle - Mustang Evolution
Old 04-30-2013, 07:03 PM   #1
buickregal79's Avatar
Odd idle
I have a stock 2001 GT with the exception of a cold air intake. I just did my spark plug well because when i got the car it had 55,000 miles and had never been done. So needless to say i did them. And every sense i got the car 6 months ago at an idle when warmed up it kind of bounces a bit i would say a 40 to 50 rpm drop it doesn't sound like a lot but you can tell and here it through the exhaust. Any ideas? Was going to change fuel filter tomorrow just because it needs to be done hoping its that but if not any one have any other ideas?
Shutting off the thought process is not rejuvenating; the mind is like a car battery - it recharges by running.
buickregal79 is offline   Reply With Quote
Old 04-30-2013, 07:56 PM   #2
Doe_Rae_mi's Avatar
Mine fluctuates as well. Does it wen a/c is on as well
Old 04-30-2013, 09:37 PM   #3
1996mustang's Avatar
Iac possibly i would clean it out first to see if that is the cause
Old 04-30-2013, 09:43 PM   #4
1slosix's Avatar
that'd be my guess
carving corners like a boss
Old 05-01-2013, 05:53 AM   #5
Cool thanks guys i will do that today and let you know how i make out! And mine does it A/C on or Off
---------- Post added at 07:53 AM ---------- Previous post was at 07:53 AM ----------
Not a huge deal just annoying lol
Old 05-01-2013, 08:17 AM   #6
Mustang936's Avatar
+1 IAC is the cause of many idle problems
Mustang936 is offline   Reply With Quote
Old 05-01-2013, 08:41 PM   #7
Jord05's Avatar
What's the iac?
Jord05 is offline   Reply With Quote
Old 05-01-2013, 08:43 PM   #8
1lowGT's Avatar
Idle air control.
08:07 PM
