Identify Transmission - Mustang Evolution
Old 05-01-2013, 09:01 AM   #1
v8pony's Avatar
Been seeing lots of posts lately regarding what type of transmission is in there NE GT, mainly 01's..here ya go straight from AM
When it comes to buying a clutch or a shifter, it is important to be able to identify which manual Mustang transmission is installed in your car. Please note that Ford not only changed the type of transmissions used in different year and model mustangs, but also changed the size of the clutch disk as well.
In order to identify what kind of Mustang transmission you have, you need to check the door tag on your driver’s side door jam. If you look down to the bottom right of the tag, you should see an area labeled "TR." Underneath this label there are 5 letters and numbers. The only one that we are concerned with is the first alpha-numeric character which corresponds to your Mustang Transmission.
If you have a 6 as your first digit, you have five-speed manual, T-45 OD Mustang Transmission. This is the standard Mustang transmission that is found in 1996 to Mid-2001 Mustang GTs as well as 1996 to 1998 Mustang Cobras. If you have a 5 as your first digit, your car came with a T-5 OD Mustang transmission. Finally, if you have a K as the first digit in the "TR" code, you have a TR-3650. This Mustang Transmission is found in mid-2001 to 2004 Mustang GT, the 2003 and 2004 Mach1 and the 2001 Cobra. The 2005-2007 manual Mustang GT' also has a T-3650.
Some of you may be wondering about the other 2-5 digits. They are related to the Mustang springs, front/rear which in this case, does not help you in identifying your Mustang transmission ...
Also where the shifter mounts the T-45 is slightly shorter than the cup on the 3650
2002 5spd GT
Feb 2013 Mustang of the Month
Old 05-01-2013, 06:51 PM   #2
White03GT's Avatar
Nice
White03GT is offline   Reply With Quote
Old 05-01-2013, 10:40 PM   #3
Good info there, few ppl are still going to be confused though because a good deal of 96-04 cars are swapped from one to the other by previous owners who didn't feel like spending the money for a quality rebuild and just get a $400 pullout since they are interchangeable. Nothing really wrong with that honestly...
Old 05-02-2013, 11:44 AM   #4
Ckennedy121's Avatar
That's what I'm trying to do. Searching Craigslist for $400 tremec 3650 to swap out
Ckennedy121 is offline   Reply With Quote
» Members Mustangs
5.0
AMLSVT8592
STANG
MedMan
Add your Mustang
06:54 AM
