Line Lock Install - Mustang Evolution
Old 05-01-2013, 09:33 AM   #1
Line Lock Install
Hey, I have an 04 GT and I was trying to put on a line lock and I realized that I'm going to need two separate line lock pumps for both rear lines. I just wanted to check and see that I'm actually doing it right.
hogan107 is offline   Reply With Quote
Old 05-01-2013, 10:30 AM   #2
...line lock installs on the front brakes...
Only one needed, install between master cylinder and proportioning valve
Old 05-01-2013, 10:35 AM   #3
DaBluedude's Avatar
Yeah. Ur not doing it right.
2003 Mach 1
Old 05-01-2013, 11:22 AM   #4
Region: Arkansas
+1
Line locks are meant to hold the front brakes only so you can spin the rears and warm them up.
I'm not sure why you're in the back of the car.
BackPressure is offline   Reply With Quote
Old 05-01-2013, 06:47 PM   #5
White03GT's Avatar
+1
White03GT is offline   Reply With Quote
Old 05-02-2013, 06:46 AM   #6
Sorry I was at work when I was doing this, but I meant front haha but anyways The one I'm trying to install is a B&M kits and in the instructions the only system that looks close to mine is system F on the instructions (which is for front wheel drive cars). So, I was thinking that I would have to do the same as that but on the front brakes with two pumps. Because my system has two lines coming off the master then the two lines go into the block and from the block they go to each wheel separately . Is it still possible to do it with one that way?
Old 05-02-2013, 06:57 AM   #7
Here's the instructions
http://bmracing.com/wp-bnmcont/uploads/46076.pdf
02:39 AM
