Which Manual Trans Fluid? - Mustang Evolution
Old 05-01-2013, 10:59 AM   #1
jjsg09's Avatar
Im draining all my fluids today and deciding on which trans fluid to pick. Im leaning towards Royal Purple right now.
Old 05-01-2013, 11:21 AM   #2
Venomouz831's Avatar
Go with ford oem, my friend once used royal purple and he said it was hard to shift, he said it was too thick and wouldn't warm up quick
)02 Gt, Founder of WE2G
Old 05-01-2013, 11:23 AM   #3
Region: Arkansas
Mercon V ATF is what Ford recommends and what almost everyone I know uses.
You can throw in some synchromesh for the gears too if you want to spend the extra money. Swap a quart of ATF for synchromesh.
BackPressure is offline   Reply With Quote
Old 05-01-2013, 01:10 PM   #4
jjsg09's Avatar
Well atf is for automatic transmissions I have the tr3650.
Old 05-01-2013, 03:30 PM   #5
goodwinta1's Avatar
Tremec says not to use the syncro mesh in the 3650 in the manual. There is a ton of discussion on what to use, and how much to use. Most say to use the GM stuff, or penzoil ATF. I just changed my fluid and used RP ATF Max. No problems for me although I only have 250 miles on the fluid. I think next time I am going to use Mobil 1 ATF. That is another fluid that is supposed to meet Tremec's specs.
Do a google search on the TR3650 fluid and you will find a million competing opinions on it. Also the amount of fluid was changed from 3.8 to 3.2 quarts via a service bulletin from Tremec.
goodwinta1 is offline   Reply With Quote
Old 05-01-2013, 04:39 PM   #6
Yeah... all the newer sticks use ATF... Mercon V is fine. I've got $3/qt Autozone brand Mercon V in mine and its fine.
Actually even a 20+ yr old T-5 will work great with Mercon V.
Old 05-01-2013, 04:56 PM   #7
goodwinta1's Avatar
Love your user name bro!!
Old 05-01-2013, 05:22 PM   #8
jjsg09's Avatar
Ok im gonna go with the dex/merc
Old 05-02-2013, 01:51 PM   #9
jjsg09's Avatar
I put valvoline dex/merc in and much better shifts. Very happy!
---------- Post added at 03:51 PM ---------- Previous post was at 03:50 PM ----------
This isn't where I parked my car! Lol
Old 05-02-2013, 03:08 PM   #10
Slow4V's Avatar
Mec 5
10:41 AM
