rattling noise, any ideas? - Mustang Evolution
Old 05-01-2013, 12:42 PM   #1
Kevo91's Avatar
Region: Utah
So I recently bought a 98 gt and it makes a bit of a rattle noise somewhere between the engine and cat on the driver side, it's not piston slap I know that much. It only does it at idle after it's been sitting, if I go for a short drive the noise goes away. I checked the exhaust and nothing is loose
Kevo91 is offline   Reply With Quote
Old 05-01-2013, 12:55 PM   #2
1996mustang's Avatar
Check again by the cat and the h pipe on my o/r x my coupler flange was missing a bolt. If anything it could be a heat shield loose or time to change out the cats if the catalyst in it has broken or been unclogged or atleast attempted to be unclogged out
Old 05-01-2013, 01:19 PM   #3
Kevo91's Avatar
Region: Utah
I'll check it out again and see, I suppose it could be a bad catalyst. The car has 160k miles and the seller said it still had stock exhaust
11:45 PM
