Spark plugs? - Mustang Evolution
Old 05-01-2013, 10:08 PM   #1
Jord05's Avatar
Spark plugs?
What spark plugs should I go with in my 2000 mustang gt ? Spark plug number would be great
Jord05 is offline   Reply With Quote
Old 05-01-2013, 10:13 PM   #2
1lowGT's Avatar
Just go to auto zone and pick some motorcraft plugs
Old 05-01-2013, 10:14 PM   #3
Boomdizzle's Avatar
Unless you are going nitrous or a blower, stock Motorcraft replacements are the best ones to get. They'll last the longest and spark plugs really aren't that different from eachother other than colder ones for forced induction/Nitrous.
Torque: It's like crack for your right foot
Boomdizzle is offline   Reply With Quote
Old 05-01-2013, 10:15 PM   #4
Ubnbit's Avatar
+1. They can tell you the stock from the computer.
Old 05-01-2013, 10:15 PM   #5
Jord05's Avatar
Ok because my car is missing and hopeing it's a spark plug
Old 05-01-2013, 10:16 PM   #6
1lowGT's Avatar
Do you know the correct gap? I think mine were already gapped correctly.
Old 05-01-2013, 10:20 PM   #7
Jord05's Avatar
No but my car runs perfect when the engine is cold but when it hits normal running temp it falls on its face and miss fires like crazy an no cel
Old 05-02-2013, 03:20 AM   #8
cliffyk's Avatar
Motorcraft AWSF32P were the original plugs for the 2000 GT, however the AGSF32PM is the common replacement--or Champion stk # 3401...
Old 05-02-2013, 06:48 AM   #9
1lowGT's Avatar
Under the the hood where it latches at on the bottom side often good there is a sticker that tells you what to gap. .054
Old 05-02-2013, 07:34 AM   #10
cliffyk's Avatar
You can download an owner's manual from Ford (click here) that has the specs for plugs and plug gap--and lubricants and capacities, etc...
02:05 AM
