how to clean plenum? - Mustang Evolution
Old 05-02-2013, 08:35 AM   #1
Horseplay's Avatar
i removed the IAC to clean it up and i see dirty gunk in the plenum? how do i clean that?
Low2v
Old 05-02-2013, 08:47 AM   #2
Horseplay's Avatar
looks like this inside .
Low2v
Old 05-02-2013, 09:20 AM   #3
Horseplay's Avatar
anyone?
Low2v
Old 05-02-2013, 09:43 AM   #4
BigB227's Avatar
Originally Posted by Horseplay View Post
anyone?
I've heard from several ford techs that the plenums have a special coating on the inside and should not be cleaned with a throttle body cleaner, I'm not 100% sure though. And that hole is where you PCV valve from you passenger side valve cover plugs in, when you have oil tere it usually is a sign that it needs replacing
BigB227 is offline   Reply With Quote
Old 05-02-2013, 10:38 AM   #5
slow281
sixpac's Avatar
Region: Nebraska
There's a special tb cleaner for fords I had some once but don't remember what it's called
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 05-02-2013, 10:54 AM   #6
Slow4V's Avatar
Just get you a good ol can of throttle body cleaner and remove your intake tube .. Open up your throttle body up and clean it out!
Or remove it and clean it if your not comftrble
Old 05-02-2013, 11:01 AM   #7
Site Sponsor
Sponsor
AMWill's Avatar
OP,
The best thing to do is remove it and clean everything out with a wet cloth. There's really no need for any hard chemicals, they just make the cleaning process easier. Clean up all the oil you can with it removed, and you'll be fine!
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 05-02-2013, 03:01 PM   #8
Horseplay's Avatar
ok thanks alot guys appreciate the help
---------- Post added at 04:01 PM ---------- Previous post was at 04:00 PM ----------
what needs replacing ? the pcv valve?
Low2v
Old 05-02-2013, 03:26 PM   #9
BigB227's Avatar
Yes the PCV valve
Old 05-02-2013, 06:16 PM   #10
Horseplay's Avatar
Yes the PCV valve
ok thanks man
Low2v
Old 05-03-2013, 09:32 AM   #11
BigB227's Avatar
ok thanks man
Anytime man
Old 05-03-2013, 10:00 AM   #12
jjsg09's Avatar
You can do this mod. It will keep the oil from going back into the plenum.
http://www.americanmuscle.com/moroso...or-9604gt.html
01:33 AM
