Brake clunk - Mustang Evolution
Old 05-02-2013, 10:06 AM   #1
98vertgt's Avatar
Brake clunk
Has anyone had problems with their brakes clunking? I have new edge calipers btw
98vertgt is offline   Reply With Quote
Old 05-02-2013, 10:40 AM   #2
Mile high JDF's Avatar
When is it clunking? When you're stopping or just while you're driving? Are you sure you tightened all of the bolts all the way?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 05-02-2013, 10:58 AM   #3
Site Sponsor
Sponsor
AMWill's Avatar
OP,
Sounds like the caliber brake is lose or something else in the suspension. You shouldn't hear any clunking, even with old brakes!
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 05-02-2013, 11:07 AM   #4
98vertgt's Avatar
I'm pretty sure everything's tighten all the way. I think the bolts might have done build up and causing a faulty tighten
Old 05-02-2013, 11:12 AM   #5
I would go through and double check all of them. Do you feel it through the brake pedal?
Old 05-02-2013, 11:16 AM   #6
98vertgt's Avatar
Yeah. Anytime I'm braking I can feel it and I've I'm cruising at under 10mph you can hear a clunk clunk clunk
Old 05-03-2013, 11:18 AM   #7
Site Sponsor
Sponsor
AMWill's Avatar
I would definitely pull the wheels and take another look. Something isn't tight and you should be able to find it pretty easily if it's making that much noise.
Shane
Old 05-03-2013, 09:32 PM   #8
98vertgt's Avatar
I can wiggle the caliper a little but all the bolts are tight. It's going in the shop on Monday so hopefully they'll figure it out
Old 05-04-2013, 04:24 PM   #9
1996mustang's Avatar
Maybe its the wheel bearings or a bad ball joint or lower control arm bushing.
Old 05-05-2013, 04:48 PM   #10
98vertgt's Avatar
I checked everything. Ball joints are fine there's 0 movement when i shake it in the air and the control arm bushings are fine too. I did notice that my passenger side wheel was much harder to spin than my drivers side. I'm thinking it might be locked up
Old 05-06-2013, 05:28 AM   #11
Quite possible i would check both wheel bearing or caliper. Gravity bleed the passenger side to see if it releases and if it spins freely if it does then that caliper is locked up
12:05 AM
