Help with P0171 and p0174 - Mustang Evolution
Old 05-02-2013, 01:17 PM   #1
Rich04's Avatar
Dam codes are still here .. P0171&P0174 how can i identify a vacuum leak? How do i tell if my 02's are bad? I changed my MAF cleaned TB and IAC valve, ran sea foam threw gas tank and spray threw intake then changed fuel filter. Car idles around 1k at a stop and if i have the heat on it'll go from 8-1300 it idles slightly rough and its been happening since i used k&n filter recharger
ID:	105623   Click image for larger version
Rich04 is offline   Reply With Quote
Old 05-02-2013, 01:20 PM   #2
BigB227's Avatar
I'm in the same boat with you and have thrown money and time and cleaning and stuff at it and still nothing I'm completely at a loss to what the solution is, I did fuel filter, fuel pump, MAF sensor cleaner, TB and IAC cleaner, changed my O2s, changed my cam position sensor and still nothing
BigB227 is offline   Reply With Quote
Old 05-02-2013, 03:01 PM   #3
CodyNelson's Avatar
Region: West Virgina
To test for a vacuum leak take a can of starting fluid and spray all around your vacuum lines and gaskets. If the idle picks up after you spray then you found your leak
Old 05-02-2013, 03:44 PM   #4
maldog's Avatar
Region: Nevada
This is the exact same thing that happened to me. Go get a new filter at Oreily or PepBoys they are about $20-25 and do not oil it. Clear your codes and put the new filter on. This will fix your problem.
I did the same thing. I took off my filter cleaned it and re oiled. Then I started get the same codes. Once you over oil the filter they will not work correctly even after trying to get the oil out by cleaning.
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 05-02-2013, 05:02 PM   #5
Rich04's Avatar
Im gonna give it a try thank you so much! That would make my car run rough aswell?
Old 05-02-2013, 07:18 PM   #6
maldog's Avatar
Region: Nevada
Oh yes...... My stang was sucking gas, running rough and codes.
Old 05-02-2013, 08:32 PM   #7
Rich04's Avatar
I tried to get a filter they don't have one that fits -_-
Old 05-02-2013, 08:45 PM   #8
maldog's Avatar
Region: Nevada
Look around..... It doesn't have to be a K & N.
Old 05-03-2013, 10:57 AM   #9
Rich04's Avatar
I know , im gonna find one today
Old 05-07-2013, 05:56 PM   #10
Rich04's Avatar
My friend gave me a filter but uhhh heres the problem
ID:	106619   Click image for larger version
Old 05-08-2013, 01:47 PM   #11
tonyd01gt's Avatar
you should be able to get a adapter to reduce it in size. Or buy the correct size off E bay.
tonyd01gt is offline   Reply With Quote
03:50 PM
