Are 99-04 intake manifold pi from factory? - Mustang Evolution
Old 05-03-2013, 09:04 AM   #1
Speed_Mister's Avatar
Region: Arkansas
Are 99-04 intake manifolds pi from factory? And then 96-98 are non-pi? I thought all 96-04 intake manifold were pi from factory?
2004 Mustang GT 5 Speed
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 05-03-2013, 09:29 AM   #2
White03GT's Avatar
96-98 npi 99-04 pi
White03GT is offline   Reply With Quote
Old 05-03-2013, 09:30 AM   #3
BigB227's Avatar
96-98 are NPI (non performance improved) which means there heads, cams and intake are NPI where the 99-04 are PI the heads,cams and intake
BigB227 is offline   Reply With Quote
Old 05-03-2013, 09:44 AM   #4
Region: Arkansas
I have a 2003.. all pi intakes have a blue gasket on top but mines red.what are the differences of pi and nonpi
Full Bolt Ons
370rwhp 470rwtq
Old 05-03-2013, 08:15 PM   #5
1996mustang's Avatar
What gasket do you mean? Have a pic? Many replacement gaskets can be different colors not all are the same color i know oem is blue
Old 05-03-2013, 08:56 PM   #6
Region: Arkansas
The gasket between the intake manifold and plenum
Full Bolt Ons
370rwhp 470rwtq
Old 05-04-2013, 05:27 AM   #7
BigB227's Avatar
I replaced my gasket and intake manifold on my 2003 mustang gt and the fel pro gasket was red
Old 05-04-2013, 07:59 AM   #8
cliffyk's Avatar
All '99 through '04 GTs have the PI design intake manifold (and cams/heads/etc). The only difference is that the early models ('99 to '01-1/2 IIRC) have the plastic coolant crossover.
The newer manifolds with the aluminum crossover are identical to the FRPP replacement unit...
03:10 AM
