U joints? Ideas? - Mustang Evolution
Old 05-03-2013, 01:47 PM   #1
Rejekt's Avatar
U joints? Ideas?
I'm having an issue with my 2002 Mustang GT.
Ok, here's the symptoms I'm having.
- When I take my foot off the gas and then get back on it, there is a loud clunk or a shudder. Almost feels like somebody is hitting my car. Also happens when the car shifts into a high gear. Doesn't always do it in either situation but sometimes.
- Seems to engage a bit hard when I go from P to R or D.
Here's what I've done so far -
- Jacked it up with both rear wheels off the ground and checked
for play at the u joints. I can't see any but I know there may be a slight bit that I'm not seeing.
- Checked trans fluid and level is good and it's clean.
- I don't see anything or feel anything loose.
Mileage is 106k and the U joints have never been replaced. I'm going to replace them just in case but would like to know if anyone has any ideas or can verify this is the issue. Thanks in advance.
Rejekt is offline   Reply With Quote
Old 05-03-2013, 03:03 PM   #2
Slow4V's Avatar
Sounds like a bad mount
Old 05-03-2013, 03:40 PM   #3
v8pony's Avatar
+1 most likely bad mount
2002 5spd GT
Feb 2013 Mustang of the Month
Old 05-03-2013, 05:58 PM   #4
Rejekt's Avatar
Yeah, starting to wonder if it's a bad trans mount myself.
Drove it home today from work and noticed that I could make it do it if I let off the gas at a low speed and then hit the gas again. Not everytime, but sometimes, it would do it.
Old 05-03-2013, 11:29 PM   #5
GP3GT's Avatar
My 99 does that too.. When i let off the gas it shudders sometimes.. Mine might be a Bad tranny mount as well
95 Camaro- Sold
99 Camaro Z28- Sold
99 Mustang GT- DD
GP3GT is offline   Reply With Quote
Old 05-05-2013, 07:15 PM   #6
Rejekt's Avatar
Update : Found the issue
Well, I got it on the lift and found a bad transmission mount. Also, I had a bit of play in my ring and pinion, so that's getting fixed and my rear upper control arm bushings are shot so I'm going to go ahead and replace my rear upper and lowers with an upgrade.
09:46 PM
