Gt wont crank - Mustang Evolution
Old 05-05-2013, 03:36 PM   #1
Sklein23's Avatar
Gt wont crank
I went threw some semi deep water. My car died on me and the water shorted out the starter. I replaced the starter, starter relay, and battery but the motor will not crank over. I have tried jumping the starter but still no luck. Could use some suggestions.
Sklein23 is offline   Reply With Quote
Old 05-05-2013, 03:38 PM   #2
Rosco's Avatar
Sounds like its hydro locked. Do you have a CAI?
1998 Bright Atlantic Cobra - 3:73's, BBK ls, Pro 5.0, 96 Cobra STB, Borla XR-1 Catback, Custom Catch Can, Spec clutch, MM Firewall adj, FRPP wires, RSD, Spoiler delete, 245/275 BF Goodrich g sports on chrome 95 cobra r's
1998 V6 Mustang : SOLD!
Rosco is offline   Reply With Quote
Old 05-05-2013, 03:49 PM   #3
Sklein23's Avatar
No
---------- Post added at 04:47 PM ---------- Previous post was at 04:44 PM ----------
Other than the exhaust the car is stock
---------- Post added at 04:49 PM ---------- Previous post was at 04:47 PM ----------
The car is bone stock other than the exhaust.
Old 05-05-2013, 03:50 PM   #4
White03GT's Avatar
+1
White03GT is offline   Reply With Quote
Old 05-05-2013, 04:00 PM   #5
98vertgt's Avatar
Hydrolocked. Even the stock intake sucks from the fender.
98vertgt is offline   Reply With Quote
Old 05-05-2013, 04:06 PM   #6
Sklein23's Avatar
I thought about that but the water was only up to the bottom of my front bumper and all I did was pull out of my driveway made it one door down and the car died. Didn't go fast enough for water to splash out into my intake.
Old 05-05-2013, 04:18 PM   #7
98vertgt's Avatar
Check your oil for water anyway
Old 05-05-2013, 04:20 PM   #8
Sklein23's Avatar
There's no water in oil.
Old 05-05-2013, 06:50 PM   #9
White03GT's Avatar
Did it die on you in the water? And if yes did you try starting it again while in the water?
Old 05-05-2013, 07:04 PM   #10
Sklein23's Avatar
Died in the water pushed into driveway and tried to start with no success.
Old 05-05-2013, 07:23 PM   #11
Slow4V's Avatar
Hydrolocked , need a new engine
Old 05-05-2013, 07:52 PM   #12
If it went up to your front bumper then water may have gone up the exhaust into the engine... Just a possibility
Old 05-05-2013, 08:08 PM   #13
Ubnbit's Avatar
Oh man. Sorry to hear about your car. Does anything work? Lights? Is the starter trying to turn over? Is it completely seized? Give us all the info you can. If there is anything else you have tried, let us know what it is so we can help. Hydro locking would suck. No doubt. Might have shorted out PCM or anything. We need to know what all is gettin fire.
Old 05-05-2013, 08:12 PM   #14
White03GT's Avatar
+1
---------- Post added at 09:12 PM ---------- Previous post was at 09:10 PM ----------
Sounds like your PCM is in need of a replacement.
Old 05-05-2013, 08:41 PM   #15
Sklein23's Avatar
With the new starter I have power to the starter and its trying to turn over but no luck. All relays have been replaced and the car has power. I'm going to take off the heads throttle body and intake manifold to make sure there is no water in the motor. And if there is hopefully I can get it all out before it causes major damage. Hopefully if there is I can save it.
Old 05-05-2013, 08:48 PM   #16
Ubnbit's Avatar
Before u tear it all the way down, pull a couple of plugs and see if they are wet and see if you have spark on them.
Old 05-05-2013, 09:24 PM   #17
Sklein23's Avatar
Ok thanks for the tip
Old 05-08-2013, 04:11 PM   #18
Sklein23's Avatar
Ok I did have water in my motor but managed to get it all out and get it started but now it making a loud clanking noise when it starts. I think I might have bent/warped a piston rod.
Old 05-09-2013, 08:13 AM   #19
1996mustang's Avatar
maybe not maybe its the oil with water mixxed into the lifters. i would highly recommend a oil change, run it for a few and do another oil change to flush out all the water contamination in the motor.
Old 05-09-2013, 08:35 AM   #20
Sklein23's Avatar
Yeah going to do that today. Hopefully it works.
Old 05-09-2013, 10:26 AM   #21
White03GT's Avatar
+1
08:05 PM
