Cruise Control - Mustang Evolution
Old 05-06-2013, 02:08 PM   #1
03RedfireGt's Avatar
Cruise Control
My cruise stopped working the other day. I have checked cable, an fuse. What else can I check
03RedfireGt is offline   Reply With Quote
Old 05-06-2013, 02:22 PM   #2
Mine hasn't worked since I got it. I never use it so i never bothered to check.
Old 05-06-2013, 03:20 PM   #3
NewMtang's Avatar
Check all your vacuum lines. They are probably old and leaking.
Old 05-06-2013, 03:26 PM   #4
Tyoung68's Avatar
Go to the cc unit and work your way back to the switch you just have to trace everything
Old 05-06-2013, 03:43 PM   #5
I have went over the vacuum lines. I had the cai off because I was cleaning it. So the first thing I checked was vac lines. It was working fine until I took the cai off. I just recently had rearend work done to. Could there be something there that might have came loose
Old 05-06-2013, 04:51 PM   #6
F8L GT's Avatar
Cruse control on a new edge doesn't use vacuum lines. If your cruise motor went out, let me know. I have one laying in the corner
F8L GT is offline   Reply With Quote
Old 05-06-2013, 05:14 PM   #7
Tyoung68's Avatar
Old 05-06-2013, 05:48 PM   #8
Will start tracing it back from the cc unit, where's it located lol. Thanks F8L, I will let you know if that's what's bad
Old 05-06-2013, 05:51 PM   #9
F8L GT's Avatar
I also have the switches
Old 05-06-2013, 05:53 PM   #10
Ok thanks, I will let you know when I figure it out
04:37 AM
