96 460 wiring help - Mustang Evolution
Old 05-06-2013, 05:59 PM   #1
stanggt96's Avatar
Region: Nevada
96 460 wiring help
Hi guys need a little help I have a 96 gt it used to have the 460 now has aftermarket head unit stock speakers stock harnes but no amps I am unable to get any bass out of the speakers not sure what to do do you need the amp to get bass
stanggt96 is offline   Reply With Quote
Old 05-06-2013, 06:16 PM   #2
02MURDEREDGT's Avatar
I had the exact same issue you have to get a special harness to connect the factory amps. Crutchfield sells it.
---------- Post added at 07:16 PM ---------- Previous post was at 07:11 PM ----------
http://www.crutchfield.com/p_1207050...s.html?tp=2977
02MURDEREDGT is offline   Reply With Quote
Old 05-06-2013, 06:31 PM   #3
stanggt96's Avatar
Region: Nevada
Problem is dont have amps the previous owner took them out
Old 05-06-2013, 06:53 PM   #4
There's your problem.
Old 05-06-2013, 07:10 PM   #5
Stray is right
Old 05-06-2013, 07:31 PM   #6
stanggt96's Avatar
Region: Nevada
So just need the amps abd I am good even withe aftermarket head unit
Old 05-06-2013, 08:13 PM   #7
Yessir
---------- Post added at 09:13 PM ---------- Previous post was at 09:12 PM ----------
You could even just buy your own 4 channel amp and DIY
Old 05-06-2013, 08:27 PM   #8
stanggt96's Avatar
Region: Nevada
I still have the factory plugs so probably look for stock amps anyone have some they are looking to sell ?
Old 05-06-2013, 09:27 PM   #9
Bypass directly to the speakers. Find a wiring diagram of the plug(s) that plugs into the factory amp/amps and match them up to their positive/negative counterparts on the headunit wiring harness. Just about any decent aftermarket headunit these days will sound better if you bypass the POS factory amps, even the Mach system which honestly is kinda crappy. I did this with my SVT Contour back when it was still running and the Pioneer 6x8s I put in immediately sounded better with the Pioneer headunit I had in there. Need to do this with my new 98 actually... have not even used the stereo since I've had it (not a DD) and need to figure out what speakers are in it and what the PO put in there. There is some sort of aftermarket amp in the trunk going to the speakers back there and a Bazooka sub that was in there too...
Old 05-06-2013, 10:14 PM   #10
stanggt96's Avatar
Region: Nevada
I will look into that thanks guys for the help anyone know what is the best drop for a 96
Old 05-06-2013, 10:22 PM   #11
What? Best head unit? Take your pic.
Old 05-06-2013, 10:30 PM   #12
stanggt96's Avatar
Region: Nevada
Best springs
Old 05-07-2013, 09:33 AM   #13
Start a new thread lol. Again, you'll have a bazillion different opinions from basic BBK lowering springs to cutting a coil off to a full out coilover kit.
07:35 AM
