E - brake hanging up? - Mustang Evolution
Old 05-07-2013, 11:51 AM   #1
Peterzinyou's Avatar
When pulling away from a stop, I can hear a slight squeal from the right? rear. Its a convt, so you apply the e brake when top goes up or down. Could that be the noise im hearing? Should I spray w brakekleen? Just had front brakes done, mechanic said backs look fine.
Borla S-Type stingers, BAMA SCT tuner, K & N Typhoon CAI, Classic Design Concepts light bar, MACH 1 chin spoiler, MACH 1000 w JVC Kvw 500 HU, plastidipped hood scoop, wing & Premium GT rims, painted calipers, 3.73 gears, black Bullitt fuel door, MMD hood struts, sub-frame connectors, SVE uca & lca, Power Stop drilled/slotted rotors
Peterzinyou is offline   Reply With Quote
Old 05-07-2013, 12:49 PM   #2
BigB227's Avatar
I'd check your calipers piston, mine was doing that god awful squeak and it was the piston going out ad pushing the pad against the rotor. I replaced caliper and fixed it
BigB227 is offline   Reply With Quote
Old 05-07-2013, 12:56 PM   #3
How can you tell? Should I just replace it. TY.
Old 05-07-2013, 12:57 PM   #4
White03GT's Avatar
+1 my caliper froze and was doing the same thing
White03GT is offline   Reply With Quote
Old 05-07-2013, 01:34 PM   #5
BigB227's Avatar
+1 only 100% way to know is to replace, I took mine off and could see the piston was bent a lil
Old 05-07-2013, 02:26 PM   #6
Thanks guys, will check after work today.
11:40 PM
