Best fuel additive - Mustang Evolution
Old 05-08-2013, 11:37 AM   #1
99mustang99's Avatar
What would be the best fuel additive or cleaner to make the fuel in my car be more stabilized and just better fuel for the engine and i run 89/91 just depending on prices, just looking at longevity of the engine
99mustang99 is offline   Reply With Quote
Old 05-08-2013, 11:42 AM   #2
If it is your daily don't waste your money
Old 05-08-2013, 11:59 AM   #3
98vertgt's Avatar
+1 i run a tank of 93 with the techron additive every time I change the oil. No use in running it all the time
98vertgt is offline   Reply With Quote
Old 05-08-2013, 12:02 PM   #4
Ive never added any to it and just wanted to add some to a tank just to clean up the fuel system a little, so whats that tetron stuff?
**Mind you i have forged internals and high strength parts btw
40,000miles on engine
Old 05-08-2013, 12:06 PM   #5
v8pony's Avatar
If you feel the need to..run tank to nearly empty, dump a whole can of seafoam in, fill up and be done with it.
2002 5spd GT
Feb 2013 Mustang of the Month
Old 05-08-2013, 12:22 PM   #6
I heard and saw a thread that seafoam cause mess with your car?
Old 05-08-2013, 12:55 PM   #7
cliffyk's Avatar
None at all would be best...
It is a good idea to switch brands now and then, as they each use different additives. Also, if your engine runs OK on 87 octane (yuk) then there is no reason to ever buy 91...
Old 05-08-2013, 01:33 PM   #8
That was just an idiot letting his vacuum line suck down an entire can of seafoam... My Mustang when I first got it had start up issues whenever it was hot (previously ran). I was running 87 at the time. I was near empty and put an entire can of seafoam in along with a tank of 91 and she barely has the trouble starting ever since. Used to do it at least once per day, it's been over a month and it hasn't happened yet.
Old 05-08-2013, 02:01 PM   #9
Yeahh im just trying to keep the car and parts maintained well thats all, i mean internals and the fuel rails/injectors werent cheap when he built it so sorta wanna keep it clean
Old 05-08-2013, 02:09 PM   #10
Cornkush's Avatar
Lolol
Cornkush is offline   Reply With Quote
Old 05-08-2013, 02:23 PM   #11
Next time you fill up put a can of seafoam in right before you put the nozzle in. A funnel would help.
Old 05-08-2013, 02:24 PM   #12
Next time you fill up put a can of seafoam I right before you put the nozzle in. A funnel would help.
Alright man, howd those parts work in that car show you went to?
Old 05-08-2013, 02:39 PM   #13
cliffyk's Avatar
Ford makes it quite clear in the shop manual that NO oil or fuel additives are needed or recommended. The only exception to this food me would be a high mileage (100k+) engine that had been horribly neglected.
We (SWMBO and I) have for 40 years regularly run our cars to 250k or more miles--I have never used any fuel or oil additives--they are not needed if you keep the oil clean and use major brand fuel...
Old 05-08-2013, 03:28 PM   #14
Neither my previous v6 nor my current v8 have had manuals in the car ( were owners cars tho ) but just the thought of ethanol and some gas around her would have some water in it, but a bp around here is opening a non ethanol pump and ill be going there for sure, thanks for the info guys
Old 05-08-2013, 07:52 PM   #15
After asking those "in the know" big brains over at BITOG, the answer surprisingly is....Techtron
Old 05-09-2013, 07:44 AM   #16
cliffyk's Avatar
You can download the owner's manuals from Ford--click here.
Ethanol is hygroscopic, meaning that to a point (a 60/40 ethanol/water mix or so) it absorbs water into solution leaving no raw water in fuel tank. It is an ingredient in some brands of "Dry Gas", the additive used in colder climates to prevent water in the fuel tank/lines from freezing.
One could also argue that the water held in solution in the ethanol adds to engine performance by cooling combustion temperatures--same as does water injection...
Old 05-09-2013, 09:33 AM   #17
Man your like a internet mechanic! Thanks a lot
Old 11-21-2014, 05:25 AM   #18
fenixignition's Avatar
name brand fuel. buddy reccomends newly opened gas stations, or popular ones (fuel gets used and replaced more frequently)
otherwise if you need to blow the carbon out, just burn rubber and haul a$$ for a bit. Road trips on the highway are supposed to help
EDIT
also, didnt meant to dig up an old thread. I forgot I was researching and not viewing whats new.
2002 GT 5sp. 16x,xxx miles
11:39 PM
