Trouble getting into gear - Mustang Evolution
Old 05-08-2013, 06:34 PM   #1
Blackedoutpony's Avatar
So my problem is when I start my car it's difficult getting into first gear and when I go to shift second gear is just as bad but third fourth and fifth are fine also going into reverse is a little tricky. The thing is I have a brand new flywheel, clutch, clutch fork, pilot bearing, and throw out bearing. But when my car isn't running it goes into gear fine. Does anyone know what it could possibly be.
Blackedoutpony is offline   Reply With Quote
Old 05-08-2013, 08:48 PM   #2
ATF has to be used. I have been using Mobil1 ATF for many years. Syncrmesh can be used also. Tremec/Borg Warner has tech articles with recommended fluids and why. Do not put additives in the transmission. Try fresh fluid and see where your at.
Old 05-08-2013, 09:59 PM   #3
1slosix's Avatar
what trans do you have? i use to have those issues with my 3650..turned out to be bad syncros
carving corners like a boss
Old 05-08-2013, 10:33 PM   #4
Ckennedy121's Avatar
Very common problem with the 3650 the synchros were made out of paper mâché
Ckennedy121 is offline   Reply With Quote
Old 05-09-2013, 02:20 AM   #5
Slow4V's Avatar
I have some problems getting into reverse , what I do is when I'm doing a cold start ill push he clutch in and run through the gears before I take off, to help ease up the transmission
Old 05-09-2013, 02:27 AM   #6
Michaelgranlund's Avatar
That's a good idea. I have the same problem with reverse on an incline for some reason but just reverse. Every other gear is fine
Michaelgranlund is offline   Reply With Quote
Old 05-09-2013, 07:25 AM   #7
The way my clutch pedal feels it has to be the cable because when I got my clutch replaced I put new trans fluid in and the stock cable was fine so I think it just needs to be adjusted. I just have to get under there because something is definitely loose
03:23 PM
