Headers and h-pipe or cams - Mustang Evolution
Old 05-09-2013, 05:32 PM   #1
Barrett775's Avatar
Region: Wyoming
Trying to figure out which one would be the better purchase first. And h-pipe and headers or new cams. What are your opinions? Already have the Super 44 American thunder series catback system. If headers and mid pipe which do you recomend?
Barrett775 is offline   Reply With Quote
Old 05-09-2013, 05:41 PM   #2
Cams!!!!
Old 05-09-2013, 05:42 PM   #3
Barrett775's Avatar
Region: Wyoming
Cams!!!!
What exactly will cams do for my ride?
Old 05-09-2013, 05:43 PM   #4
Slow4V's Avatar
Long tubes and x pipe first
Old 05-09-2013, 05:44 PM   #5
Tomb1987's Avatar
Header mid pipe. Cams make no sense if your just gonna push all that extra air through stock exhaust. As for brands I don't really have a preference on headers and midpipe. I do recommend off road h-pipe though. The xpipe will make alil more power but IMO the xpipe sound like crap the hpipe sound way better
2002 mustang gt
Future beast
Tomb1987 is offline   Reply With Quote
Old 05-09-2013, 05:45 PM   #6
Barrett775's Avatar
Region: Wyoming
Off road H-pipe is the pipe without the cats am I right?
Old 05-09-2013, 05:46 PM   #7
Tomb1987's Avatar
Yes offload means no cats
2002 mustang gt
Future beast
Old 05-09-2013, 05:48 PM   #8
Barrett775's Avatar
Region: Wyoming
That's what I thought. Usually a little louder than catted. How hard are headers to install?
Old 05-09-2013, 05:50 PM   #9
Tomb1987's Avatar
Headers are not the easiest install but not bad. Maybe a 6-7 hrs or so with help. Loosen the motor mounts and jack the motor up to get more clearance!
2002 mustang gt
Future beast
Old 05-09-2013, 05:51 PM   #10
Barrett775's Avatar
Region: Wyoming
Good thing I have friends to help lol.
Old 05-09-2013, 05:52 PM   #11
Joey8's Avatar
Don't long tune headers get ride of the cats? Make sure you get an h pipe that'll fit your headers
2014 Sterling Gray GT (Ordered1/24) (Built2/25) (ETA3/12) (Picked Up 3/21)l 443.9/417.8 l
l l 6 Spd l Prem Pkg l Nav l TP l LthrRecaros l AmericanRacing 1 7/8 LTs l O/R H l JLT CF CAI lVMP Tuned l BorlaS Quads w/ResDel. l GT500Valance l KoniStr.T l K-Springs l GT500 Mounts l BMR UCA&LCA l BMR Relos l BMR Panhard l SpeedDawg Knob l 5.0 LloydsMats l Redline HoodStrts l Bobs CF Oil Sep. l 15% Tint l CDC Grille l StrtScn2 ChinSpoiler l GT/CS Fogs w/4500k l RTR DeckLid l CF Engine/CoilCoversl
Joey8 is offline   Reply With Quote
Old 05-09-2013, 05:55 PM   #12
Tomb1987's Avatar
No not always. Most of the time they eliminate the cats but I've seen mid pipes for long tubes that still have cats
2002 mustang gt
Future beast
Old 05-09-2013, 05:58 PM   #13
1lowGT's Avatar
You really need to open your exhaust up before cams. Now stock manifolds and o/r mid pipe will do good. Then cams. Or full exhaust then cams. Like said headers are a pain but can be done with help.
Old 05-09-2013, 05:59 PM   #14
Barrett775's Avatar
Region: Wyoming
Well cats aren't required in Wyoming so I'm not worried about passing any sort of emissions testing. So I will be going off road when I do this. Thanks guys
Old 05-09-2013, 07:00 PM   #15
Tomb1987's Avatar
No problem.
2002 mustang gt
Future beast
Old 05-09-2013, 07:04 PM   #16
Cats are required federally and it is illegal to remove emissions components from a car that originally had them. With that said, in Wyoming you'll never have to worry about it and there are plenty of ppl myself included who have run around in emissions states with no cats at one point or another.
As far as headers, not needed on a 4.6L until you get into much bigger power numbers. The stock manifolds on a 4.6L are not restrictive like they are on an old 5.0L and, as I've said numerous times, there is a reason the Terminator guys don't usually upgrade their manifolds until the 600hp level. What you need is a better midpipe, gears, then work on suspension/chassis stiffening, traction and the driver mod. Plenty of stock motored bolt on 4.6L PI cars with 4.10s in the 12 second range.
Old 05-09-2013, 08:02 PM   #17
I live in Cali and have no cats, I think you'll be fine.
Old 05-09-2013, 08:11 PM   #18
MidnightBlueGT's Avatar
Free up exhaust before cams. Doing both will be awesome
Old 05-09-2013, 11:03 PM   #19
Tomb1987's Avatar
+1
2002 mustang gt
Future beast
Old 05-10-2013, 12:13 AM   #20
1lowGT's Avatar
That's one the first things you need to do it free the exhaust up then time I.
Old 05-10-2013, 01:06 AM   #21
Slow4V's Avatar
Or the easier way to drop the K member just a little more time
---------- Post added at 02:06 AM ---------- Previous post was at 02:04 AM ----------
You need supporting mods if your going to do cams that's why alot of people do Tb, plenum, full exhaust, gears, before cams
Old 05-10-2013, 12:24 PM   #22
Jord05's Avatar
Drop the k member makes things easier and go with x pipe and headers first just did mine and wow woke her up like crazy it's like a new car !!
ID:	107146   Click image for larger version
ID:	107148   Click image for larger version
Jord05 is offline   Reply With Quote
Old 05-10-2013, 02:39 PM   #23
Tomb1987's Avatar
Go on YouTube and listen To x vs h pipes to see which u like
2002 mustang gt
Future beast
Old 05-10-2013, 08:58 PM   #24
Barrett775's Avatar
Region: Wyoming
Ill have to do that.
---------- Post added at 09:58 PM ---------- Previous post was at 09:58 PM ----------
Thanks for the tip
07:07 AM
