4.6 over heating - Mustang Evolution
Old 05-10-2013, 10:02 AM   #1
Scream's Avatar
4.6 over heating
My dads 02 steeda is still over heating after he just rebuilt the whole engine brand new 0 miles. He put in an upgraded thermostat to keep it cooler. My friend has a 96 4.6 l and his was over hearing Untill he took out his upgraded thermostat and put a oem thermostat back... Any body else have a problem like this before ? Or know why this may be happening ?
Scream is offline   Reply With Quote
Old 05-10-2013, 10:15 AM   #2
tonyd01gt's Avatar
when you change the thermo. did you reprogram the PCM to make the fan switch come on with the new degree thermo
tonyd01gt is offline   Reply With Quote
Old 05-10-2013, 10:23 AM   #3
Scream's Avatar
No idea lol he may have. I honestly have no idea what that means
Old 05-10-2013, 10:48 AM   #4
tonyd01gt's Avatar
the computer tells the electrical fan to come on at a certain temperture. it keep the engine/ radiator cool. it keeps the car from overheating
Old 05-10-2013, 10:56 AM   #5
Rosco's Avatar
Do the hot water test to see if the thermostat is functioning properly.
1998 Bright Atlantic Cobra - 3:73's, BBK ls, Pro 5.0, 96 Cobra STB, Borla XR-1 Catback, Custom Catch Can, Spec clutch, MM Firewall adj, FRPP wires, RSD, Spoiler delete, 245/275 BF Goodrich g sports on chrome 95 cobra r's
1998 V6 Mustang : SOLD!
Rosco is offline   Reply With Quote
Old 05-11-2013, 09:44 AM   #6
Scream's Avatar
How do you reprogram PCM
Old 05-11-2013, 09:57 AM   #7
White03GT's Avatar
Disconnect the negative battery terminal for about 20 min
White03GT is offline   Reply With Quote
Old 05-11-2013, 10:10 AM   #8
Scream's Avatar
He had it like that for a couple weeks when he was putting engine in lol
Old 05-11-2013, 02:32 PM   #9
White03GT's Avatar
Have y'all checked the thermostat? Could be the water pump too
Old 05-11-2013, 02:40 PM   #10
Scream's Avatar
I think it is thermostat its an upgraded one so maybe can't handle it
Old 05-13-2013, 08:16 PM   #11
Rosco's Avatar
IMO I wouldn't put a autozone/cheapie thermostat in my car. No idea how well the wax pallet is set to open up coming from in their providers.
Old 05-13-2013, 08:28 PM   #12
1996mustang's Avatar
Imo if u wanted to run a much lower thermostat the ecu shouldve been reflashed doing a battery disconnect wont do the trick unless its a oem alternative like the 180° thermo. To truly take advantage you would have to have a tuner or a shop rewrite it for the ecu for the fans to kick on around say 175° for a 170° thermostat or so on and so forth just like i said imo
Old 05-13-2013, 08:30 PM   #13
Tkcobrasvt's Avatar
You need to make sure your engine/hoses are burped properly. I would just drain all the fluid and reburp the system. I just did this on a customers 98 gt I did a PI head swap in last week. Also check your cool fan fuse. It's the first fuse on the junction fuse box. I attached a diagram below.
Tkcobrasvt is offline   Reply With Quote
Old 05-13-2013, 08:34 PM   #14
Ahhhh i almost forgot check the lower hose.....it happened to me on a 5.4 swap we ran everything riggt but the lower hose was starting to cave in under vacuum sorta while running. We replaced it with a hose witg spring in it to maintain it feom collapsing. When the hose collapsed it was causing it to overheat even with everything set up correctly. I would suggest checking that out on his stang.
Old 05-15-2013, 09:15 PM   #15
tim_mcc's Avatar
Can anyone tell me how much the coolabt volume is in a 2003 GT?
tim_mcc is offline   Reply With Quote
Old 05-15-2013, 09:32 PM   #16
14.1 quarts.
Old 05-15-2013, 09:39 PM   #17
tim_mcc's Avatar
Dang thats a lot. Lol thanks man.
Old 05-15-2013, 09:41 PM   #18
Haha. Thats what I thought too. No problem.
Old 05-15-2013, 09:51 PM   #19
tim_mcc's Avatar
I was reading places that were saying 14.6 quarts. Was like wow. If my math is right thats like 11 gal. No?
Old 05-15-2013, 09:54 PM   #20
Rosco's Avatar
1 gal=4 qt
So no
Old 05-15-2013, 09:54 PM   #21
Its a little over 3.5 gallons.
Old 05-15-2013, 09:59 PM   #22
tim_mcc's Avatar
Wow thank you I feel really smart no. I need sleep and a day off at some point. Lol good lookin out man.
09:34 AM
