custom guage pod - Mustang Evolution
Old 05-10-2013, 07:17 PM   #1
2002VertGT's Avatar
custom guage pod
ok, so with the pending procharger install on my 02 gt ive been thinking of ways to hide my guages so that they can not be seen by just everyone driving by....kinda sleeperish. if i cant figure anything out ill just mount them with the cluster bezel pod but would like something a little more custom. Anyone know how hard it would be to make a pod that attatches to the pass side of the center console? i know it would eat up into the passangers leg room but i rarely have a passenger so they can deal with it. Was thinking of adding it to the pass side kinda angled towards the driver so i can see it with a quick glance but its not up for everyone to see since i have a Convertible. Thoughts??
4.10 Gear/RPM thread
Old 05-10-2013, 07:21 PM   #2
MidnightBlueGT's Avatar
Wheel stander has a bada** setup and has his mounted under the stereo. You could mount there or get a pod for the steering wheel
Old 05-10-2013, 07:30 PM   #3
So every a-hole can't see them at a light... in the slot under the radio/hvac, you can cut out the area around the cupholders and have a billet plate fabbed up to go over that area with 2 and 1/6 gauge holes and there is also the tried and true cluster bezel with the 2 gauge pods. Those would be sort of visible but not overt.
Old 05-10-2013, 09:14 PM   #4
Mile high JDF's Avatar
+1^ latemodelrestoration sells a mounting bevel for it. I would have mounted mine where the radio currently is if I didn't have issues with the stereo being in that position.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 05-11-2013, 11:16 AM   #5
2002VertGT's Avatar
Mine has the double din the pic is just one of a console I found.......would it be possible to fit them in the shifter bezel with some modification? Anyone think that's wide enough?
Old 05-11-2013, 01:02 PM   #6
You could try doing that but it might just be easier to the double din out of a 99-00 and go from there if you don't mind choosing a different radio.
Old 05-11-2013, 02:01 PM   #7
Then there is this guy
Lol not exactly what the OP is looking for but I like it and its MUCH nicer than the POS autometer pod that ppl install there. That Autometer pod isn't even contoured to the dash...
Old 05-11-2013, 03:05 PM   #8
2002VertGT's Avatar
Something like that is what I was thinking about just on the pass side of the console....
---------- Post added at 05:05 PM ---------- Previous post was at 05:04 PM ----------
If I do it this way ill have to wait longer to find a single din radio that u like that will work with mt Mach 1000 system
Old 05-11-2013, 03:45 PM   #9
Or just delete the Mach 1000 system and get a good set of Pionner speakers, bypass the stock amp and it'll sound way better.
Old 05-11-2013, 04:09 PM   #10
WheelStander's Avatar
Thanks Midnight for the comps... I'll find the link to the thread on it.
Gauge faceplates for CD player?
Induction: Kenne Bell | wHp: 515 Tq: 503 | 1/4 Mile:11.09@123
WheelStander is offline   Reply With Quote
Old 05-11-2013, 04:17 PM   #11
PIC
Old 05-12-2013, 06:08 AM   #12
2002VertGT's Avatar
Originally Posted by WheelStander View Post
PIC
Ill have to eliminate my buttons to switch to that bezel....fog and tc I'm not to worried about but the rear defrost?!
Old 05-12-2013, 06:15 AM   #13
2002VertGT's Avatar
So you are telling me that 4 pioneer speakers sound better than the stock amped speakers with subs?
Old 05-12-2013, 07:13 AM   #14
tc x 4's Avatar
PIC
Winner, hands down.
Old 05-12-2013, 07:40 AM   #15
Thanks tc.
Pickup a fascia at junk yard for 99 or 00
Mustang.
You can mount your switches back in same location, just drill some holes.
Old 05-12-2013, 09:31 AM   #16
A set of 4 GOOD Pioneer speakers will sound light years better than the Mach 1000 blah speakers and the Mach subs are pretty terrible as far as subs go. It will sound better yes, just not as much bass. Throw a good amp and a single 8 or 10 inch sub in the back if you want the bass back and sounding better.
Old 05-12-2013, 06:16 PM   #17
BigB227's Avatar
Not tryin to steal the thread but where can you find gauge pods or pillars for a 2003 mustang gt convertible? All I ever see is for coupes
BigB227 is offline   Reply With Quote
Old 05-12-2013, 09:22 PM   #18
03fastblack's Avatar
Glowshift.com
03fastblack is offline   Reply With Quote
Old 05-12-2013, 09:53 PM   #19
Zamora03's Avatar
Here's a few
ID:	107724   Click image for larger version
Zamora03 is offline   Reply With Quote
Old 05-12-2013, 10:07 PM   #20
2002VertGT's Avatar
Originally Posted by Zamora03 View Post
Here's a few
That fox is like what I want....the others are too visible....I'm seriously considering buying a spare shifter bezel and playing around with it to see if I can fit 3 Gauges in it
Old 05-13-2013, 03:57 PM   #21
IMO, if you are really that dead set on the low vis gauges. Get the speedometer bezel that has 2 and then do the 3 below the HVAC. You need: Water, Oil, Fuel pressure, Wideband and a boost/vac if you supercharge it.
Or just ditch the stock cluster entirely and get a aftermarket gauge cluster which is what I eventually want to do. The stock gauges are not very accurate.
Old 05-19-2013, 03:05 PM   #22
Zamora03's Avatar
Not a bad idea
Old 05-19-2013, 10:38 PM   #23
2002VertGT's Avatar
Not a bad idea
That's something like what I was talking about with the custom part....building a little thing off the pass side of the center console to hold gauges. Or putting them in the front of the shifter bezel where the lighter is.
10:16 PM
