Safe tune - Mustang Evolution
Old 05-10-2013, 08:48 PM   #1
MidnightBlueGT's Avatar
Safe tune
So im ordering exhaust next week most likely and am wanting o/r x but im keeping the stock h to swap out for inspection, but in the future im getting a s/c with a custom tune. so is the custom tune safe for swapping between catted and o/r mid pipes?
Thanks in advance. Love how this forum helps me with my to do list lol.
Old 05-11-2013, 09:35 AM   #2
cliffyk's Avatar
Other than turning off the catalytic converter monitor routines (by disabling the rear O² sensor signals and heaters); catted or non-catted has nothing to do with tuning our engines.
Nothing to worry about...
Old 05-11-2013, 10:45 AM   #3
Thanks man, appreciate it. I really wanted an o/r midpipe
Old 05-11-2013, 06:06 PM   #4
Just make sure you are sure the cops around you won't care. I ran around with an O/R pipe for 7 years in NJ and never once had an issue with the police pulling me over for noise or suspecting I was not running cats. My buddy in Wisconsin was pulled over THE SAME DAY, he put his O/R pipe on and fined.
Old 05-11-2013, 06:11 PM   #5
That sucks!
Old 05-11-2013, 09:19 PM   #6
cliffyk's Avatar
A 2-1/2" "off-road" H- or X-pipe will make the exhaust absurdly load and stinky, and not pass emissions testing--and has NO performance advantage over a 2-1/2" "high-flow" catted pipe that will not be as loud or as stinky; and will pass emissions testing.
Why people want one is a mystery to me, but if they do then go for it--WTF...
Old 05-11-2013, 09:27 PM   #7
He said he is going to keep the stock pipe to swap out. I did the same thing every 2 years on emissions day. And no the exhaust is not absurdly loud and stinky. It CAN be too loud for some places especially if you get obnoxious mufflers. I do agree that a good set of high flow cats is not going to really suck up any noticeable power. As far as the smell, as long as you have a set of tails on there its not going to get into the cabin or cause any issues. I ran the O/R pipe for years like I said and never got pulled over once. Combo was FMS ceramic shorties, MAC O/R H pipe and a Dynomax Ultraflow catback.
Old 05-11-2013, 09:49 PM   #8
03fastblack's Avatar
I am running Mac O/R H pipe and slp lm1's and my car is starting to miss on timing I think. It will even kinda jerk when its driving and at idle it makes a popping noise every few seconds. My cousins car did the same thing with the same set up. Do you think it's because of no back pressure?
03fastblack is offline   Reply With Quote
Old 05-11-2013, 10:10 PM   #9
cliffyk's Avatar
back pressure myth 1, and back pressure myth 2...
Old 05-11-2013, 10:12 PM   #10
I didn't think it did but idk what the it could be. Ill replace the plugs and see
Old 05-12-2013, 08:50 AM   #11
WheelStander's Avatar
Midnight...no worries with the cops where we live and ah... Get the mil eliminators and there is a shop Lake Norman way to get your car passed. Nc does not do tailpipe checks anymore.
Induction: Kenne Bell | wHp: 515 Tq: 503 | 1/4 Mile:11.09@123
WheelStander is offline   Reply With Quote
Old 05-12-2013, 10:34 AM   #12
I'd check the COPs and do the plugs/tune up and go from there. What you describe should not be caused by the exhaust. Might just be a bad O2 also.
Old 05-12-2013, 11:38 AM   #13
I'm assuming its the o2's. thanks man
Old 05-12-2013, 12:36 PM   #14
What's it called??
Old 05-12-2013, 12:43 PM   #15
Originally Posted by MidnightBlueGT View Post
What's it called??
They just ignore that they're suppose to look at the cats?
Old 05-12-2013, 03:44 PM   #16
Pretty much they take your word that the muffs are hi flow cats.
You can give me a call when you need to go.
Old 05-12-2013, 03:52 PM   #17
1lowGT's Avatar
Well I'm his cousin. And my car only misses that's making a pop noise every few seconds. I have already changed my plugs and one of the cops. Will a tuner get rid of that?
Old 05-12-2013, 04:02 PM   #18
What's it called? Ill need to in august so i probably will.
Old 05-12-2013, 04:12 PM   #19
cliffyk's Avatar
Unless you have some radical cams and the miss is at idle or low RPMs, or your current tune is quite bad, there is nothing a tune can do to fix misfires--there is some other problem
Old 05-12-2013, 04:14 PM   #20
1lowGT's Avatar
Nope lol stock cams. Alright I think I had the problem figured out
02:17 AM
